Chris, this unit has a DVD player in the boot which uses the xanavi Cd to use the Navigation unit.
Makes me wonder that if i replace the DVD player and buy a whole new in dash system with navi, i could prolly use the the same brackets / wiring and wont have to do whte whole thing over. agree?
it has a satellite thing that sits on the dashboard.
  • Replies 72
Posted Images
WOW GUYS GUESS WHAT!?!? Just then on my drive, I turned the ignition, decided to press the open button (I do this everytime I go for a drive) and this time, the head unit opened!!!! It was amazing, it worked for about 2 minutes, the CD player too!! The CD player I left in there it went off for sure!! I heard a subwoofer at the back which I didn't know if it still worked, maxed out the speakers for those 2 minutes, then all of a sudden, it went dead, nothing displayed on the screen and the CD player didnt work anymore... WHY is this so? Connection problems? Should I take it apart and rewire the connections!?
more photos for my system
i was thinking of getting something like this done. though im not sure who around tiny geelong would. Probably JB hi-fi, but i don't want to go ask for a quote till i have the dosh ready.
http://www.youtube.com/user/mightycarmods#p/search/6/lTuMWxzrMHE
If any of you have any links to good cheap systems / know anywhere around this side of melbourne / vic that would do stuff like this pls let me know.
thanks
If you need a replacement of those units in your dash, I've got the lot for sale lol.
It's from a R34 GTR, but I think it should be exactly the same? Also have a boot carpet with a factory CD stacker, and lastly a din pocket with lid lol.
another question
I was watching Top gear (s01e04) where they review R34's. They show that the screen in car shows the onboard computer logistics as they drive. is this possible for all r34's or whats the deal?
Yup, it's definitely possible, many people have that conversion.
Turbo or NA, both works, it's just that if you put it into an NA, it will only show throttle, rev light, oil temp, injectors, voltage.
But a MFD (multi function display) is costly, can cost anywhere between $600-$1000. I just sold one without looms for $600.
Here's a pic of my R34 GTT interior.
I have the same setup as grey in my skyline, is it possible to just change the pop up screen to like a GPS or something.. i also went to JB HI-FI and they said they can change the head unit and put a new frame and that for just over a $100 is that worth it ?
gotta love these people that think cheap is the way to go. its not. to do it correctly it is a AC controller swap,panel swap and then a screen swap.
that screen is data driven and has to see data from the navi system first BEFORE it will fire up. without the navi system its just about useless.
I have one to do on thursday and I will post a few pics up on the shop facebook page.
i dont really care about the screen or nav system that came with it, was just wondering if i got rid of whats in there already could i replace it with something else
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
