Purchased this car back in august 01 for a whopping $23K as a 1st owner in Australia car.
Car has been through alot of changes and been subject to my learning car stuff by tinkering with her since i bought it. This is one of the reasons i have decided to redo the whole car from the ground up as there was too many "just make it work" moments in the past and this led to the un-neat solutions that this attitude creates. Im sure we all know what thats like.
car was purchased with :
Volk EMU racing 16" rims
tanabe coilovers
HKS SLD
Black s1 M spec kit
Will try to find some old photos of the car when i bought it and post them up later
Here is how the car sits right now :
HKS GT3040 on stainless manifold
Tial 38mm gate
custom exhaust
sard 550c injectors
Sard FPR
044 externally mounted
Power FC
Z32 AFM
Tomei Poncams
Plazmaman Plenum
PWR radiator
making 290rwkw some years ago after i finished the install on hitmans dyno on 98ron
Been through a few changes over the last 5 months also with the addition of Tein Flex coilovers and removing the subframe and replacing all the bushes.
Car now :
Plan for the car is to get it ready for engineering and also make it more comfortable and reliable, then get back out on the track :)
https://www.sau.com.au/forums/topic/357621-craved-revamp/
  • 3 weeks later...
  • Replies 184
Posted Images
hopefully keeping this thread updated will help me with the motivation to get stuck into this rebuild. Even if i didnt know it had been approved already lol
Brake Kit :
Consists on EVO IX brembos
Custom 355mm rotors on alloy hats front and rear
Rear calipers where spaced apart 4mm to allow for the 32mm thick rotors - allowing for a more common thickness rotor for cheaper replacments
rears - and the reason i had to sell my work meisters :(
no room for the caliper in there :P
Hence the 350z rims - picked them up for $200 off ebay, so got them coated up in Black chrome and it turned out to be a real nice combo with the cars colour and the rim design. Its not flush but goes well with the $300 semi slicks i picked up 2nd hand from Gordon Levin Tyres.
Advan AO48 - 235/40/R18
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5746211
At the end of last year i took out the rear subframe for a big overhaul - New bushes everywhere, from subframe to arms to the 2way mechanical diff mounts
Split down to this:
Then fixed up and turned into this :
With the alloy rear hat it will the extra cooling provided by the 2 piece rotor, but i lose the ability to use the handbrake while in motion - so no sliding that way for me
Hicas lock bar was finally installed when this was all re-installed into the car
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5746246
so heres the old interior, fibreglassed in that boost guage and had the oil and water temps replacing the old hazard lights and demister switches. idea with those was to be legal while more in line of sight than the DINN console
Then i got these :
and after having this car for so long, dealing with rattling pillow ball tops and fuel pumps in the boot i decided i wanted this car to be comfortable to drive, while having plenty of power and as good handling as i can get it.....so i did this
So to match the new R34 GTR seats i got the door cards and rear panels retrimmed in as close a match as i could find.
The seats i got were modified to fit some non-skyline so i had to cut the mounts off the stock seats and weld them back onto the GTR seats - still only done this for the drivers seat so far
Rear seats were also installed from a 34 GTR
new front seats changed the driving position, so i purchased some deep corn to resolve the issue :)
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5746247
Powdercoated my own set of RB26 covers while i was prepping some other parts (been sitting in powder primer waiting to go for near 2 months) , really like this colour
Love how the RB26 looks
So after some thinking about engineering and the work i need to do with piping and ceramics on the hot side i've finally decided to build my RB26/30
Only bits left to get are :
AAC and IAC
Injectors
new PowerFC - hoping to score a D-jetro
New Exhaust Manifold
Oil pump
Crank Collar
VRS kit
everything else i have already collected - so hopefully i can get the crank collar soon and installed on the crank asap
then i'll be assembling the motor myself, nothing fancy just rebuilding the rb30e block to standard as im not after big power, just a bit more drivability.
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5766101
cheer mate,
re: handbrake
Im using a 2 piece rotor on the rear. specially made rear alloy hat is hard annodised for durability, but still cannot withstand the use of the handbrakes shoes on it while in motion.
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5766188
How did you find that sound deadening idea worked? How much and where from?
Without the rear seats in my R34 transfers a fair bit of road noise through the cabin... :glare:
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5769089
i got a mega pack from the USA, was a long time ago so dont remember the price now
as for how it works, well i havent driven the car since doing it haha
i did notice that from doing the front half of the rear quarter panel (under the 1/4 window) that opening and closing the door has more of a thump to it than before. thats without touching the front doors yet
i have 2 sheets left out of the 9 sheets in the pack which did the 1/4 guards and the rear seat area you see in the photos. I think to finish the front half of the cabin and the boot i'll need another 2 boxes.
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5769104
I used my friend :google: and i found the company in the US... They have a new version called the SUPERLITE which is an obvious advantage for the performance side.... They have prices online for the pack similar to yours and its about $350 USD (Not sure about freight though)
If it gets rid of the road noise it will be worth doing...
What do you mean by "More of a thump"? is it just because you sealed it up and its airtight?
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5769121
Just less reverberation when shutting the door, like nice new cars
checkout ebay US too for the dynamat, definately cheaper than buying locally even when the dollar wasnt as good as it is now
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5769131
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
