Hi all! Name is Viet, just got an m35 stagea 2weeks ago but its got some minor problems.
My faint engine light keeps appearing even after ressetting the ecu, it comes up with code 0171 which i believe is left bank lean. I notice that my car drinks alot (18l/100km) so im suspecting the o2 sensor which from nissan is $160 with a 2 week wait.
Also notice that on my stock exhaust only the left tip is working, the right is clean.
Does anyone know if the skyline v35 o2 sensor can be used and also if the v35 nav unit will work in my stagea as it was missing from purchased?
Having a hard time of finding basic servicing information as in:
Oil used, how many litres to fill up?
Oil filter part number?
Spark plug number and gapping?
Transmission fluid and capacity?
Diff fluid and capacity?
Also would the arx shocks and springs fit my stagea? Ive got rsr springs atm and i go fishing alot so doesnt clear the dirt roads.
Thanks you advance!
If anyone lives in the western surburbs of melbounre and would like meet up please pm me, would love to learn more about these cars!
4wd fluid and capacity how to bleed?
https://www.sau.com.au/forums/topic/357701-m35-stagea/
OK, I'll bite. Can't give all the answers but some of them.
Don't worry, it opens up when you give it a boot full. the exhaust is variable and contains a pressure flap inside.
1) don't know 2)the Nav function will never work as its Jap only. Buy a UBD. it would be a lot of work to get the shit in there.
4.8 or something like that - most of us are lazy and just dump a 5 litre bottle in.
I can't be assed going downstairs and looking - just ask for something from a 03 350Z you'll get the right one. its fits a shitload of nissan cars.
Different people have had different experiences. Have a search on the site.
Nissan Matic J, or Nulon 100% sythn seems to be the other proven performer. about 8.5 litres - remember you have to flush it not just drop the Pan, that'll only get about 4 litres.
Redline shockproof - about 1 L per diff I think. Use good quality cause you don't want to change it for a long time...
Don't know. should have bought an ARX....:thumbsup: Might be the worlds only Raised Stagea!
Nissan Matic D / ????
Hope that helps you to some extent.
I'll let the other guys handle the error message- I have my own thoughts but they are more experienced.
https://www.sau.com.au/forums/topic/357701-m35-stagea/#findComment-5717272
The ARX springs will get you a little more lift, I didnt swap my shocks over but I've got ARX springs in; with Nismo springs my front lip was 8cm off the ground.. Looked AWESOME but killed me in terms of functionality. Im now somewhere around 15cm off the ground at the front. So if you need some height and can source the springs, do it thumbsup.gif
https://www.sau.com.au/forums/topic/357701-m35-stagea/#findComment-5717312
I've got a set of factory ARX springs and shocks in storage if you must go higher. But I recommend lowering of the RS/RX for bitumen and finding a ute for fishing.
I know what you mean about the exhaust tips. I didn't realise until now that the Calsonic has a pressure flap - clever. I just thought mine was always blocked .pinch.gif
Agree with everything PN-Mad mentioned. I replaced my transfer case and Attesa fluids and there is lots of good info on how to do it with the search. Both fairly easy but I needed an extra hand with bleeding the Attesa pump.:thumbsup:
https://www.sau.com.au/forums/topic/357701-m35-stagea/#findComment-5718317
Hey Gazza,
Did you replace your ARX suspension with BC's ?
How is the ride now?
https://www.sau.com.au/forums/topic/357701-m35-stagea/#findComment-5718423
Hey Gazza,
Replaced the shocks with Bilsteins and the springs with original-height (ARX) King Springs heavy duty. However, I've recently seen a heap of lowered ARX and they do look better - even with the flared guards. I just find the tailgate doesn't open high enough so at the time decided against lowering.
The ride is firmer but still comfortable. It just suffers now from the factory sway bars but Dale will soon sort this out with the Whitelines.
https://www.sau.com.au/forums/topic/357701-m35-stagea/#findComment-5720916
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
