man im soooooo keen!!!!
ill give ya my address right now! while im at it ll pay you're travel expenses, i hope its ok if i just give you my credit card details?
if not ill tell you my pay pal account details.
seriously mate, make a f**king effort, im surprised this thread is still here.
https://www.sau.com.au/forums/topic/357822-feature-cars/#findComment-5720472
https://www.sau.com.au/forums/topic/357822-feature-cars/#findComment-5720553
Dont mind people on here Chad, its because they don't own a Lexus :P
But as per said, some more info on what it would be used for would be nice.
Magazine?
Album Cover?
Personal benefit?
DVD?
https://www.sau.com.au/forums/topic/357822-feature-cars/#findComment-5720802
