Just throwing this up for discussion as i have never seen it mentioned with this particular turbo
As it is results for the Garrett GT2859R - 707160 - 9 is very few and general consensus is that it is a more efficient turbo than the R34 N1s aka -7 but is not as good as the -5 for out right pwr
AFAIK the -9 IS the Gtss minus the actuators.....
Has anyone used or contemplated using the -9 with the larger .86 A/R turbine that garrett offers, up from the .64 A/R ?
I'm assuming everyone who has used it so far has used the .64 a/r turbine, and did the gtss kits offered from hks had options for the turbine size? or did they just stick to the .64 a/r turbine as well?
Anyway i guess the main concern here will be the increased lag from the bigger turbine but.....will it still be less lag than the -5s with the advantage of a little more pwr... maybe up to 350rwkw?
Claims from -9 vary between 300-330rwkw but is the comp maxed at this output? If not maybe the larger turbine will make it do a little more without taking a full step up to the -5
Discuss.......
Edited by Don Dada
https://www.sau.com.au/forums/topic/357831-garrett-9/
There is no option for .86, nor would you chose that rear as the comp wheel runs outta flow - not the rear when -5s use a .64 and have made 380-400rwkw without a problem in the world.
All you'll do is get more lag, without anymore power
Only -10 come with the .86 option, and only -10's on a 3ltr should use .86
https://www.sau.com.au/forums/topic/357831-garrett-9/#findComment-5718855
yes the 0.86 housings are not the GTR housings so not a bolt on. and it would be a fair mismatch having 2 turbos with a tiny compressor and a 0.86 AR turbine housing, especially if you still have the same little wheel in it. waste of time. and there is no housing option for any of the HKS GTR bolt ons. GTSS are 0.64 and so are HKS 2530s for that matter.
https://www.sau.com.au/forums/topic/357831-garrett-9/#findComment-5719722
Ok thats good info that hks didnt make their kits in anything other than the .64 a/r
Garrett shouldnt put it as a "direct replacement" and offer the .86 a/r as an option if it doesnt fit tho....and i found it strange that they didnt offer it for the -7 too
Wheres disco to get into the nitty gritty?:cheers:
https://www.sau.com.au/forums/topic/357831-garrett-9/#findComment-5720096
Parkes waiting to work the Indian home .
As was said the 0.86 A/R GT28 turbine housing is an SR configuration turbine housing not the more compact RB26 type one .
As others said they would be too big anyway for an RB26 and possibly not terribly responsive on a 2630 particularly with 707160-9 turbos on it .
The 0.64 A/R RB26 housings , Garretts and HKSs , seem to flow plenty with the GT28 NS111 turbine in 76 trim so I doubt there is a need for 0.86 housings to suit RB26's .
Cheers A .
https://www.sau.com.au/forums/topic/357831-garrett-9/#findComment-5720152
I was sitting in a motel room in Parks (central western town in NSW) waiting to work the Indian Pacific back to Sydney Central Terminal . I don't work with turbochargers for a living , well the the big diesels do have them , but I pedal trains for a living .
A .
cool job mate. :)
https://www.sau.com.au/forums/topic/357831-garrett-9/#findComment-5722929
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
