  • Replies 334
Posted Images
People i'm still awaiting tracking numbers for are:
J34
A20089
CASSBO
WLSPN
EIGHTSIXBOY
That sux, I was one of the first to pay :( Bloody pommies, mine's still stuck in the shop.
My oil cooler rocked up today, looks really good!
I'm just awaiting an email (hopefully tonight) with the rest of the tracking numbers.
Mine says:
Aug 8, 2011 1:13 AM -- In transit -- ALEXANDRIA AU
Aug 7, 2011 9:32 PM -- International shipment release -- ALEXANDRIA AU
Aug 7, 2011 9:32 PM -- In transit -- ALEXANDRIA AU (Package available for clearance)
... maybe it'll get here (Adelaide) tomorrow?
... Just wish I had the car to fit it to - Four Months since my accident, and it's still being repaired .. *sigh* :(
Well if it has been sent (like they were supposed to) straight after ours then yeah you should. But given the track record with delays.....who knows.
Got my oil cooler today. Damn it looks good quality. Well worth the wait. Thanks again Phil! I still hope you continue to do more group buys.
Woo. Mine just arrived. Looks nice, all the guys in the office were admiring it - hah :D
Wonder if you can get black braided lines to give it the ultimate stealth look ..
Question - are you only supposed to get one mounting bracket (original picture showed more)? I'm guessing that's enough, anyway?
Yeah just one mounting bracket, it will be more than fine to hold it up. I might not even use it and make up some custom brackets. Will see how it goes mounting in the drivers side front gaurd.
J34 - Yeah i'm still waiting on yours and the other guys tracking numbers. I wish companies had better communication. I mean I understand people are busy and all but when you have some ones money communication is key! Hell I feal bad if I don't reply to some of your guys PMs after 24 hours!
UPDATE
The rest of the kits have been sent so I will PM every one their tracking numbers now :)
Also regarding the black fittings, they are is such short supply that Hel have an allowance of 5 of each black fitting a month! So they will just have to send them out as they come in one person at a time. I will go last so every one else can get theirs first. Unfortunately that's the best they can do :(
Who knows...
I think they will try and send them out as soon as they can though. Might mean two people a month or more....or just one lol.
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
