  • Replies 334
Posted Images
Could you take some pics on where and how you fitted it? :thumbsup:
I just ran it without oil filter relocator kit, all fitting up, ready for track day Saturday :)
Can someone please advise whether the sandwich plate in this kit has a 1/8 NPT tap in it?
I have one of these kits sitting at home but I am not there at the moment and I need to know ASAP as I want to buy an oil pressure sensor thingy.
PS - are those black fittings any closer to being sent out?
Damn it, no taps into the sandwich plate....
  • 4 weeks later...
Will there be another group buy soon?
Or can anyone tell me where to get a similar kit with the thermostat?
And are people simply using a relocation kit:
http://justjap.com/store/product.php?productid=18043&cat=299&page=1
over the top of the HEL adaptor plate?
Yes
What size fittings is the core as I have a cooler that I cant use as its to big but the 25 row would possibly work.
What I have is 370x290x50
No problems, I can live with these fittings. I know you went through hell on this group buy (and the other one too!) and I'm just glad I got such a good quality kit for a good price.
:cheers:
I don't think so. I have lost contact with them and quite honestly have given up on it. Sorry guys.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
