Well ive been building a drifter for the past few months, i bought it as a completely stock r32, didn't even have a fmic or a boost gauge. Since starting the build ive done the mods below.
Hks Split dump into 3" Kakimoto ( ill be running strait of dumps on track anyway )
Fmic
Welded diff
Pod filter
Tune up ( plugs, oil, timing belt, thermostat, water pump )
52mm Alloy rad ( stock clutch fan and electric thermo fan setup )
Boost and temp gauges
Hdi Boost controller
Safc
vg30 op6 Turbo
My next thoughts were to get a better exhaust and intake manifolds then go for a tune before hitting the track. When reading about the vg30 turbo i assumed that a safc would be enough to play around with to get the car running nicely with the new turbo, But have since been advised i need to spend another grand or two getting nistune installed and a tune with it before getting any benefits out of the new turbo, So im slightly annoyed and confused.
So far i have test ran the car with the new turbo @ 15 psi, Pressure holds @ 15 on stock rb20 actuator from around 3500 to 7000 and doesnt drop off at all, ive not been able to give it a really good test because i dont wannt be speeding around in an unregistered drifter.
But so far it does feel that the stock rb20 turbo @ 15 psi pushed me into my seat more than the vg30 one at 15psi, again ive not got it tuned yet.
Any thoughts / opinions are welcome!
https://www.sau.com.au/forums/topic/357906-need-info-what-next-to-do/
Nistune cost's $420 for the ECU and budget about $300-$400 for a tune depending on how much is required.
e.g My old R31 skyline, but a cam and cam gear in a nistune at the same time. Took 3hours to tune from the factory tune.
also you would probly notice a power loos if you went to your track exhasut set up if you tuned the car with a street exhasut (due to the lack of back pressure). IMO just keep the exhaust on when u drift. Your current exhaust should be fine.
Also you mentiond you are going to use both clutch fan and thermo fans?? Can u elaberate how u plan to set this up. However for your info a clutch fan generly flows more air then a thermo fan set up thus better cooling.
You're spending too much cooling the engine and not enough hotting it up!! Read the turbo upgrade threads above to see what you need to do. e.g. manifolds do not need replacing - get your stock turbo highflowed. Nistune fitted and tuned should be less than $1000.
1. Sell the SAFC
2. Install a nistune and get it tuned
3. Stop waisting time and money on power and start on handling modifications
4. Some HSD coilovers
5. Caster rods
6. Rear camber arms
7. Hicas cancell bar
8. Decent alignment set up!
Then save up for a bunch of wheels any tyres, then more tyres and some more tyres....
J.
NIStune boards for RB20s are only about $220 if you don't want a license for the software, $50ish for a competent electronics tech to fit it, few hundred bucks for a tune.
Don't bother with upgrading intake and exhaust manifolds, too much expense for little to no gain or as far as intake manifold goes, you will go backwards. The RB20 really needs those long runners. Stock exhaust manifold is good for up around 300rwkw too.
  • 2 months later...
1. Sell the SAFC
5. Caster rods
6. Rear camber arms
J.
Everything this man said.
You'll go through about 3 pairs of tyres a day.
Get some BC coilovers, they're like $1200
TuneAgent Adjustable castor rods $260
and some adjustable camber arms.
Driftworks do a kit for like $2500 that includes coilovers and pretty much everything else you'll need to make the setup adjustable and delete hicas. I don't know about the quality of that kit as I havn't done a lot of research into it.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
