he did 260rs cradle.
i did s14, everything lines up, i used the same diff i was running but obviously needed to use the shorter half shafts. lower control, camber, toe and traction arms are all the same and interchangeable.
while the cradle is out, replace the subframe bushes with whiteline units or equivalent
Actually out of a RS4S, same as 260rs thuo.
You can use a R33 GTS (non turbo) IE no hicas rack to worry about, same as S14, S15
GTST has hicas which you don't want so just adds more expense to fit a removal bar
sway bar is not the same!
The wider auto sway bar will fit the smaller cradle, but it won't work the other way around with standard parts.
Aftermarket ones are the same. i'm running a whiteline 27mm R33GTR sway bar in my series 2 auto stagea
So Mike, hopefully you can chime in here once again?!
how much clearance do you think you had here roughly? (50mm, 60mm?)
The wheels I'm looking at will have about 20mm less inner clearance when your 9.5 +1's so here's hoping I'll still have some room left.
to give you an idea, with the factory manual rear i could fit 9.5 +22's in the rear but they juuuuuuust touched the coilover body.
fitted a 15mm bolt on, and with a gaurd roll and stock camber arms they are about 5mm inside the gaurds when the suspension is full compressed - ie, they don't rub.
so in summary, on a manual rear end, a 9.5 +0 fits with only flattening of the lips and would sit 'hella flush' - and clears the struts easily.
that's with 235's fitted
Edited by SMOKEYC34
Going of that Mat, it's going to be f**king close! If i run minimal camber (and maybe a slip on spacer if I must) I should be right.
Next delima, the wheels I wanted aren't avaliable for another 3 weeks or so, and I don't think the dude is 100% on selling them.
Edited by Run-It-Hard
Framed
The Wed’s have found themselves a new home, they are now living on Julie’s S14 and they look great on it. What brang this sudden thought upon me you ask? Well after a bit of research and asking some members on SAU, I’ve discovered that it’s possible to eliminate the extra rear track on automatic Stageas.
The items needed are a S14 turbo rear sub frame, and R33 rear drive shafts. The main benefit of doing this is so you can fit a more aggressive wheel at the back, just like the fronts.
The items bolt straight up to standard mounting locations too which is a great bonus. I’ve got a set of wheels in spastic sizes lined up too (hopefully), the rears will be pushing it though so I hope I can pull it off!
I’m still very indecisive with the Stagea too, I can’t decide whether to let it go, or hold onto it … I’m sure I’ll figure it out soon enough.
Keep it. You know you want to!
Can you still take it out to the skid pan with no license? I figured you probably could if someone else drove it out there??
Yeah, skidpans pretty gay though I want to hit up the big track but the car isn't ready yet.
Man, it's been 3 weeks, but I must say no licience SUCKS!
Awesome rear mat! If you sell the car...sell me the mat!
Someones mad jelly aye hahaha.
The Stagea in all it's dirty glory! Missus has put her foot down and told me not to sell it, normally when I rebel against her desicions I end up regretting my own desicion. So I guess I'll just have to put that manual in huh, what a shame! haha. I might do it steps though, so manual first, drive it around and then power mods? still not sure at this stage ... waiting for the outcome on these wheels I want.
Are you still going to have to change to fork end rear shocks using the s14 subframe? I need to do the same thing as the new wheels i've got are sitting about 30mm outside the guards at the moment and I haven't even dropped it down again yet from the height it was at when I had my stockies on. Also i'm not using stretched tyres either, and am not getting rid of the 255's that are on there as they're near new and cost a fortune. And from what I understand using the narrower subframe is going to pull the inside of the wheel closer to the shock and lower spring seat (I've got the SK group buy kit, so bilsteins with a largish spring seat compared to most coilovers)which is also worrying me. So I'm going to have to use spacers to clear the spring seat. Why do the final motion wide body guards have to be so pricey :)
Yeah I was thinking that would still work, but the only other thing I was thinking about is won't the shocks have to be pulled in towards the subframe more to bolt up again (as everything is moving 50mm in). I know there is some movement there but is it enough? Correct me if I'm wrong here though..... And also depending on what shocks/springs or coilovers you'd be using, you'll probably have to space it out again to clear the shock body and/or lower spring seat although not as much as 50mm? I'm not doubting that it works as people on here have done it (although I thought they'd used the fork mounting shocks instead) just trying to work it out in my head :)
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
