  • Replies 158
Awesome! That was an hilarious night. Love the piss takes.
I did a full length version with a different intro and outtro, but YouTube limits and ISP timeouts stopped it from going up... ...Part 1 even had a strange cutoff at the end because it's 6 seconds over the 15 minute limit... ...I'm looking into how to go over 15 min... ...but shorter are better on my ISP...
episode 2
I was there that night , no trophies for me but at least I got a feed.
But now back to the GOR trip , here's part 3 & 4 of my videos of the day.
(it's pretty much the same as part 2)
Part 3
http://www.youtube.com/watch?v=gyvFsO6u8sY
part 4
http://www.youtube.com/watch?v=mspCShLvovA
I had trouble putting this up on Photobucket & I
had to edit it for Youtube.
Quick preview of the next episode...
PM me your number plate and your power so I can add it to the episode... ...or if you'd like your car to stay out of the next episode PM me also... ...(Sorry John, if you didn't want yours in the vid. I can always take the preview down once the full episode is finished)...
  • 1 month later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
