I realise this has been done a number of times but as I am about to get my motor re done I would like to try & make sure what I understand to be the case is actually correct - plus get some opinions.
Question is this: Of the two options (see below - varying in flow rate & sump capacity) is the first sufficient or should I be spending the coin on number 2?
Basically the build is straight forward & nothing flash. Approx 500rwhp from a Rb26 for use at supersprints & hillclimbs. Forged pistons, mild cams etc etc. It has been going fine on option 1 for a few years but the rebuild will have another 100rwhp.
Anyway the question comes to the oiling options. As I see it there are two.
1. Stock sump with Tomei windage tray, N1 oil pump (For the new build I would like CNC ground replacement gears - is this the 81mm Reimax version?) & a 1.5mm restrictor
2. Higher volume sump, Nitto or Jun or similar aftermarket pump with 1.1mm head restrictor.
Please do not concern yourselves with oil in the head issues as for the purpose of the argument they dont count. Nor for what it is worth worry about rants on N1 pump reliability.
https://www.sau.com.au/forums/topic/358667-rb26-oil-pump-choices/
Option 1 will be fine.
Ensuring 1L of overfill in the stock sump. Plenty have done this without issue. only time issue has arisen is when they forget to overfill
Or, to throw a spanner in the works...
Option 1.5using all of option1, but changing sump. This setup is what most GTR's use. Only diff being stock N1 pump, no gear swap.
I think though the N1 and Nitto have the same flow rate? Meaning restrictor choice should be same across both.
So it's a vote?
I vote higher flow and smaller restrictor
Reimax gears in a N1 pump will probably end up costing close to buying a jap high flow pump by the time you buy both and them and put it together
Now, here come the VIC guys saying N1 pumps are awesome...
Howdy i" IT ALL COMES DOWN TO $$$COIN$$$ ! SIMPLE"
Option 1 is under a grand JPC.com (victoria) do N1 Billet Gears $350 ,N1 oil pump new from the states $200 ish tomei Sump baffle $200 ish (if you dont have one)
option 2 is over 2 grand Tomei pump and sump only way to go is the best and the rest start to stack underneath most are pretty good and nearly as good but none do a three peice gear like Tomei (just cant break them)
Okay
Option 1 will eventually fail depending on lots of stuff but another build will be needed later than sooner
Option 2 pretty much never a problem and the best option for a stock position Oil Pump and dearest also
Option 3 DRY Sump (external) oil issues on a race GTR Sorted if you have issue with oil its the last thing you will suspect
1.5mm restrictor is fine but if only doing track work and mostly in the 6000rpm plus ie no street cruzing then 1.1mm restrictor (Check Tomei website for this)
Good Luck
SIR-032
Problem is I cant find a stated flow rate for the N1 pump anywhere. Nitto is about 40% over standard (not N!1 which to my mind is approximately a *#%^ load of oil.
Can you confirm if this is correct: N1 is the 11 internal tooth pump (not teeth really being a Gerotor pump but you know what I mean) with a larger diameter than the standard pump (12 internal teeth)?
Okay
Good Luck
SIR-032
For what it is worth it has an N1 pump in it but that would get a new gear if re - used.
It already has a Tomei baffle too & gets 5 litres of Mobil 1 dumped in it every oil change.
It is not a question of dollars it is a question of getting the system to work harminiously - for me anyway.
You say option 1 will fail - due to the pump or due to flow rates?
Option 3 is not an option for me.
One is eventually likely to fail but the other isn't?
Oh come on, thats just rubbish.
There is no credible shred of proof that stays using option 1 will invevitably lead to a rebuild, or that option 2 will totally avoid it.
A motor failing is no less likely with option 1, than it is with option 2.
The same risks/issues are present. The only thing that is different is the Tomei pump is stronger. Doesn't mean it wont break, doesn't mean its indestructable. Doesn't mean there are not 100 other possible reasons or area's that could kill the engine.
Indeed I've not seen them written anywhere.
Although a fair few posts around here seem to suggest anything other than stock - most of them are around the same.
R31 Nismoid You do not even know the flow rates of a RB26 oil pump So important mate !!! you loose credability straight away
I have just rebuild my motor and have done stacks of research and actually have done the tests and have also had the heartache
I am Right you are Wrong Simple admit it move on and shut the thread if you so choose to
Read what you want into it mate i have used general language and have not said definite rather probably and eventually
SAU is really given me well i dont know well maybe and i thinks
cany find real info mation on this damn round about of a way site you wanna know my experience PM me all ill tell you REAL life engine touching blowing up fixing INFO
Forget Cyber google Fringing Guess's PM me or leave my REAL opinion and facts alone
Have a great weekend EveryBloody
" what i wrote is not rubbish" and there are good reasons behind it
"Pump and Sump "read the Thread properly Oil Pump Around $1600 Sump around the Same so with Oil Pump Sump and Front diff rebuild Around $3500 actually
Sorry from your lack of punctuation it appeared like you thought the pump was over 2k. My mistake.
Punctuation, try it sometime :)
have actually have done the tests and have also had the heartache
So what are the flow rates of the N1 pump then oh intelligent one? I take it from the fact you didn't post them - you don't know either?
What are these "tests" you've personally performed on all these parts?
Please post the results for all too see, you know, so you don't loose any credibility.
I'd like to know, as I'm sure everyone else would, how you know that you'll "pretty much never a problem" :rolleyes:
Definition of eventually: in the end
Same could be said for option 1, 2 or 3, eventually all things will fail.
I mean, eventually you'll die and so will i. See how much of a ridiculous statement that is yet?
I'm civil :)
People just spout a lot of what workshops feed them without knowing any better. Thank god he doesn't post here all that often.
I know that you've got enough smarts to see through that and look at results, cars and the overall.
Obviously with added oil/larger sump the oil temps and similar are beneficial to the cause depending on use.
Snowman & Scotsman both ran stock sump'd GTR's for 2-3 years no problems in that department. Motors were stock too and eventually the died but that's what happens @ 330-360rwkw over a hard life. Since then they've both used N1 pumps, as have pretty much all Vic cars. Not one has broken a pump yet. Most motors hand together fine as well (failures are not pump related).
So if you are a bit worried then swap out the gearset. They aren't too expensive and if you get piece of mind then that's covered off.
Comes down to cost really:
Option 1 - 1500
Option 1.5 - 2300
Option 2 - 3200-3500
I'd also suggest if you are going to go all out on a pump, that you use the Tomei one. It's the only one that utilises a different gearset arrangement similar to that of the 2JZ (never hear of them breaking pumps). It's something I've never really worked out why the other aftermarket pump makers don't use the Tomei/2J style as for a bolt-on pump, it's the way to go.
I'm civil :)
Option 1 - 1500
Option 1.5 - 2300
Because I have some stuff already (N1 pump & Tomei baffles) in the car option 1 is probably down around $500 tbh - but it is not a $'s issue.
For what it is worth (& I have tried to avoid all this) most pump failures I reckon to be down to materials of construction (ie sintered metal) limiter bashing and/or busted harmonic balancers. I mean, yes, inline sixes have inherent crank harmonic issues due to the length of their cranks but an RB26 is such a tiny thing it shouldn't cause massive drama.
The Tomei kit looks nice - flow looks to be +20% on stock. I would like to know how this stacks up against an N1 pump but it doesn't appear the numbers are anywhere to be had sadly.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
