R34 GT-T wrecking whole vehicle, currently have all parts available if you need something thats not listed let me know as I've just put up the things I could think of.
Take the whole car for $4,500
RB25DET NEO
Welcome to come hear it running, mechanical inspections welcome.
104,000kms
Complete engine:
Loom, ECU, AMF, Injectors, Intake manifold, exhaust manifold... put a turbo on it and away you go.
$2,200
4-Speed Tiptronic Auto Gearbox – $200
Panels / Lights
Rear bumper $50 (scrape)
passengers Rear Guard $200
Rear Boot + Wing $200
Passengers Brake light with garnish $130
Drivers brake light no garnish $80
Boot Interior - Complete $150
Rear Window- Tinted $100
Passengers Door $200
Drivers guard $150
Bonnet - Bought to replace damaged item $250
Interior
Complete Seats front and rear $
Steering Wheel
Dash Cluster
Center Console parts
Suspension / Braking
Rear Cradle - Diff, Drive shafts, all arms undamaged $400
Tailshaft $100
Complete Brakes Front and Rear $800
Castor Rods $100
Lower Control Arms $200
Parts SOLD/Damaged:
Front Bumper
Drivers Guard
Drivers Rear Quarter panel
Drivers Rear Brake Light Garnish
  • Replies 47
Mate I'm after the axle, or th drive shaft as I think you call it.
The part (bar) between the Diff. and the wheel on the driver side.
Do you still hae it ? and how much do you want for it including shipping to sydney??
Thanx
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
