dont bother putting it into your dads name, you will need to be listed as a percentage driver of some sort, and the premium will always reflect the youngest driver.
Best and cheapest are two things you will soon learn don't go together in the same sentence when owning a skyline.
FYI, try SGIC, Just Cars and Shannons.
Have you ever had any insurance before even thidr party?
If so, i would go with just cars as they recognise this and will give you the equivalent full comp insurance.
you also have young and cool, vigil and famous car insurance.
Pays just to ring around as you need an insurance history at some stage in your life and it is better to start now rather than later.
Make sure you get an insurance approved alarm and a club lock for the steering wheel the more deterrants the better.
Yea, unless you are over 25 and no accident history for 3-5years Shannon's probably won't insure you.
Just saying.
I have proof they insure under 25's.
Krishy - R33 GTS-t, no accident history. Insured by Shannons for a couple of years now
Me - R34 GT-t, no claim history or crash history, Shannons wont insure me
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
