Hello all,
Just got myself a 98 R34 GTT coupe and would like to perform a major service to make sure that all the fluids/oil is good. :D
Does anyone have a suggestion on the list of "fluids" I should change? ie. Engine oil, power steering fluid, auto transmission fluid, break fluid, etc.
Also what sort of reasonable brand/type I should get?
Sorry.. a newbie, so be gentle with the answer please. :)
Cheers,
https://www.sau.com.au/forums/topic/35919-first-major-service-for-a-gtt-r34/
if u want cheap genuine nissan parts for ur service pm me cause im a 3rd yr apprentice
the price difference i get is awesome like i got 6 platinum plugs for a mates 32 and his price was like 120 buks i got it for him for 60-70 buks
ur only catch ur on the coast and im in bris
ur call dude good luck
Hello all,
Cheers,
i would change all filters - air/fuel/oil
all fluids- coolant, engine oil, brake, gearbox, rear diff,clutch
plugs, lube bump stops and driveshaft etc.
good luk
They plugs in An R34 GTT are Platinum to begin with.
Unles you are going to gap them down for higher boost, down change them.
I only just changed mine at 45000klms because I was gapping them down.
BASS OUT
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
