Hey guys
Bit of a pickle here, I'm ordering some Volk GTCs for my r33 gtst series 2. Now the rears are finalised and will clear brakes (19*9.5+24) but for there's a bit of an issue wit getting the right offset for the fronts.
I'm ordering through Jesse Streeter, and I got him to ask RAYS if 19*8.5+29 Face 2 (Disk A too, which is supposed to give more clearance) would clear my front brakes. Now they replied that they have never tested it, thus cannot guarantee that it will clear.
I'm just wondering if this is just due to them being conservative, or if the offsets and spoke design are actually cutting it fine?
The offsets don't seem rediculous for an r33 gtst (i had 8.5 +22 before) but it's making me wonder if it's got more to do with spoke design?
Thanks guys
Oh, also if anyone has a 33 with gtc's, feel free to post up pics and specs :) I only seen a handful on SAU, from my haphazard searching techniques
https://www.sau.com.au/forums/topic/359290-brake-clearance-issue-volk-gtcs/
offset will NOT affect brake clearance.
you can have a +50 or a -50 and the spoke will be the exact same distance from the calliper, it's the actual wheel that will be in a different spot.
if anything those will probably hit the UCA...
this apply for all rim designs or only some, cos my eurolines dont fit the front deepdish 9+30 but with a spacer they fit so effectively altering the offset?
if im wrong i just learnt something new
Nope Hamish is right.
A spacer doesn't change the offset, it simply move the entire rim outwards. Think about it, you are in essence adding length to your hub.
The only time offset alters brake clearance is if it starts to change the spoke angle. Ie on a TE37 with a high offset the spokes are flat, however when you go to a low offset the spokes start to bend outwards.
So to answer OP's question, you will be fine. I have GTC's and they don't even come close to hitting the brakes.
if you had your eurolines in a lower offest you would still need to use the spacer as they just have shit brake clearance.
most jap rims are available in a few differing "faces" or spoke shapes.
by adding a spacer, yes you are effectively lowering the offset and moving the whole rim outwards, but this is not indicative of factory offsets where the correct stud length is retained...
try to think of it like this:
the spokes are always in the exact same spot, no matter what offset the rim is made in, but the position of the rim will change.
this is probably easiest to imagine with something like work meisters, as they are a 3 pc rim.
they make the spokes (all exactly the same) and then simply bolt them into differing places on the rim to create different offsets
well it changes the effective offset not the fixed offset.
ie a 9 +30 with a 25mm spacer is effectively a 9+5, i know the rim structurally isnt changing but the whole mounting position is moving outward thus giving more clearence in effect.
or no?
or no?
that is 100% correct :)
ah thought so, soo offset can be relevant to brake clearence.
either way OP should get better sizes/offsets and let his nuts hang low.
Only when talking about spacers as you are increasing the width of the hub. You aint changing anything about the wheel.
Regardless what offset he chooses it aint going to affect brake clearance unless the spoke design changes such as my TE37 example.
but the point is if he uses a spacer to reduce his effective then that will improve brake clearance
Hey guys
Thanks guys
They would be fine, mate. I've also got 19x8.5 +5 (Face 2) at the front of my V35 coupe and there's plenty of room. Plus I asked alot of mechanics if I can upgrade to bigger brakes with these wheels, all of them said I can. :)
Good luck.
Edited by VNS 24
are you talking about factory brakes? of course they will clear. your factor wheels are like 16X7 with +35 or +40 offset and have thick spokes and still clear the puny factory brakes. and you're worried a set of aftermarket 19inch wheels won't fit? seriously? dude you could fit your brakes and a pizza dish in there.
Ahh I see what what you mean. It's just the position of the "barrel" of the rim that changes....so basically, if I'm picturing it right, having a lower offset would then give more suspension clearance? As the barrel of the rim is positioned outward more? Or is that a rookie mistake? lol
Your car's actually the inspiration for going with GTCs, looks bloody mint....don't worry, will be going a different colour tongue.gif
Yeh the reason I used those offsets was because I thought I needed to....The next offset down is 8.5 +17, extra 13mm of dish (total 55mm) biggrin.gif. The rears in B disk 9.5+24 already give 73mm of lip, which is plenty to keep me happy lol. Next one up is 9.5+12 and 86mm...
Yeh that's what I thought too. The only reason I posted this was on the advice of Jesse. He got a reply back from RAYS stating that the GT-C Face 1 19x8.5J+28 (B disk) won't clear my brakes. I think this may be more to do with the spoke design (Face 1 is flat spokes, Face 2 is concave) and the fact that it was B disk, or they could've just made a calculation mistake, I don't know. Either way, rather get a few opinions first before blowing all that cash money.
Oh and thanks for the info guys, much appreciated
Yes that's correct.
Your car's actually the inspiration for going with GTCs, looks bloody mint....don't worry, will be going a different colour :P
Hahaha all good man, cheers.
Post up pictures once you have them. I want to one day piss off my rears and put some deeper dish 19" on the back for the staggered look.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
