Hey All,
Pickup my “Volvo” last night!
Got a few small things to do to her already like change out coil packs and rocker cover gaskets but apart from that she drives really well.
Items so far:
1997 S1 Stagea RS Four with 170,xxx kms on the clock (has receipts and log book)
Leather interior
Dual moon roof’s
Full kit (Not sure what brand, can someone help with this!) I’m assuming Nismo at the moment…
Bilstein suspension (struts and springs)
Z32 front brakes
Profec boost controller
Shift kitted auto
Tow bar with reece hitch
Greddy boost gauge
Things to do:
Yellow jacket coil packs (installing this weekend)
Install Defi gauge set (this weekend)
Install Bosch 040 (maybe this weekend)
HID head light install
Clear front indicators
Dolphin front grille
Autech or Dolphin rear wing
S2 Tail light conversion
17x10 + 15 BBS mesh rims (or 18x9.5 +20 undecided at the moment)
Photos:
  • Replies 482
here what i have found
Midland towbars will get a towbar 1000kg from the eastern states and charge $795 fitted ....1 week wait and fitting 2-3 hours
rockingham towbars will make you a 1200kg towbar for $850 or a hayman (square tube type for $1050...needs car for 2-3 days
Someone told me that haymen reece make a 1600kg towbar but i rang them and these have never heard of such a car :(
Hey Mazzas,
Yeah mate, same guy on PSB :)
Was into cars way before I found bikes but now share the passion of both types of racing. I actually bought the Stag so I can pack all my track days gear into it and trailer the race bike around and sleep in the back if necessary. The Stag is much nicer than any ute in the same price range plus I already know how to modify work on them.
i am rsvpaul i went for a few rides with you until i had a stack on th aprilia
i will be looking at modifying this one alittle soon just got to remember its actually my mrs car.
I drove it back from adelaide last week and there is plenty ive room to sleep in her :)
  • 3 weeks later...
i think Zack at Cypher Industries is good with stageas. i know he has a c34.
and mel at evoR is starting to get in to them as well
but i do most of the work my self i only send it to some1 if i not have the tools or i have not done it befor
Edited by whitenight27
Well hope ur rough idle is not the same as what mine has.
I have had a slight misfire and rough start in the morning for about 8 months.
In the last 3 weeks the misfire got worse and it started to idled rough at the lights. So I tried another set of coilpacks with no result
Only today I removed the spark plug from cylinder 6 only to find that it was full of coolant :-(
Now having to change the head gasket and hoping that is all thst it is
Haven't posted in a long time, but very desperate here. Need a set of stock wheels with reasonable tyres, or a pair of wheels with decent 225/40/R18 wheels ASAP close to Bassendean. One of my rears just started to delaminate, and the other one is very close to it.
  • 1 month later...
First off, gersfan, ur f**king moving bug thing got me, I tried to squish it :/
Secondly, this page is building a WA Stagea community, for mods/meets and general discussion, already have a few, so the more the better XD
https://www.facebook.com/groups/308340292591887/
  • 1 month later...
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
