ok well im building my rb26 head and have ordered tomei 10.8mm lift cams with tomei type a springs, im just wondering how good the standard rb26 valve spring retainers are, if anyone has had problems with them failing or if i need to upgrade them. or wat upgraded ones are good to use. last thing i want is for it to drop a valve. cheers liam
Get the titanium retainers as well mate with the extra pressure of the upgraded valve springs you will split the standard retainers and i got the tomei type b valve springs and they come with the retainers.
  • 3 weeks later...
just get the supertech set up. double springs titanium retainers and good for 13mm lift. about 600 deliverd
+2
Went from another performance spring manufacture to super tech and literally went from 480rwhp too 596 rwhp.
Back to back with nothing else changed but the tune to suit th new springs that would actually work over 22 psi
  • 2 years later...
Old post, saves starting a new one
Il prob be changing my valve springs when I do my cams, I see a lot of brands like Brian Crower, hks, greddy etc that come without retainers, are the stock ones good enough for these replacement single valave springs?
Only looking at running poncams around 9.1lift
Still running standard valves but with new valve guides, seats etc
Edited by SiR_RB
To much seat pressure is not good. You need to know what it is you want first. Then build around that.
I dont see a need for so much lift. 10.5 and higher.
In short ro much seat pressure just loads up everything in line with to much stress.
Thats just my to cents.
But I guess I should have asked you what are your hp goal. Sorry
Most proberbly go type r poncams so around 250x9.1 lift,,,nothing extreme
Won't be going double valve springs as there no need for my choice of cams, just wanted to know if standard retainers will be fine with upgraded single valve springs
  • 1 month later...
Ok I got my cams now looking into valve springs
When do you need to run a titanium retainer?
How much is too much seat pressure? Is 80-90lbs seat pressure closed and about 180-190lbs open too much?
Will be running around 26-28psi boost and rev to 8200rpm
We have had GReddy springs with stock everything for years. 264 and a 272 with 9.7 lift. Used to rev it to 9500 and havent seen an issue after about 8000klms. Most of its life its spent on the dyno or the drag strip so its not being babied at all. We run 25psi apart from when its being driven to and from the dyno or drag strip ;)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
