Hi All,
Just looking at next steps and how to push things from my current 279rwkw (hypergear hi flow turbo with return flow intercooler and standard piping).
I am wondering what power people have made with a return flow intercooler and standard piping inside the engine bay?
Possible areas of restriction are the 2.5" cold pipe and the fact that the cold pipe and hot pipes are right next to each other.
Any help much appreciated!
Seen a certain brand of return flow max @ 270rwkw recently on a car that was done.
That said - you shouldn't be asking the question, you should be testing it.
Measure boost pressure turbo outlet, measure pressure near the plenum.
No point trying to theorise something like this as there are many factors to take into account. Testing will tell you without a doubt if there is a problem or not.
Eeeeeeeee
Eighty
Five
Yup thats the plan just dont want to find out that the setup is restrictive so I couldnt get the most out of E85. Trent was saying they did an RB30 with a GT35 and 0.63 rear and it only gained 10-20 rwkw with E85, but I attribute that to the stupid 0.63 rear on an RB30!
piping is not really going to make a diffrence look at ripsfed he is running 2.5" from turbo to intercooler then 3" to throttle and god knows how much power he is making im running 2.5" from turbo to cooler then 3" from cooler to throttle body
260 to 307 when I converted to e85 plus tomei cams on less boost and im still using air box and jjr return flow cooler so you shouldnt have a probelm I would expect you to make around 310-315kw mark
Yeah I understand, my hot intercooler pipe is currently getting a fitting welded onto it so I can measure the pressure before the intercooler. I also just purchased an infrared thermometer so I can measure the temps at different stages along the piping.
More just interested to hear peoples stories of how much power they are making through a return flow intercooler with standard piping.
I am assuming both of you are not running return flow type intercoolers though where the pipes run side by side, plus my intercooler to throttle is also 2.5".
Depending on where the piping is it could be sucking up radiant heat.
Doesn't mean the air inside the pipe is the same temp though... That again, needs to be used with a in-pipe sensor to really get a good idea. You'll get an indication yes, but given you weld a bung in anyway to test pressure - not hard to have it dual purpose and get it 100% accurate.
Great to hear, I believe you have the 0.63 housing as well? I am concerned as my current turbo cant make any more boost so I am worried that will limit the E85 conversion power increase.
Great to hear that you have a JJR return flow cooler and an airbox, thats exactly the info I was after! thanks!
I run a Blitz return flow on my 34 and it has no problem with 350rwkw on E85
Great news thanks! Do you run the standard intercooler piping? Is there anywhere I can read up on your mod list?
Yes good point although if the pipe is super hot on the outside some of that heat is passed on the air flowing past.
stock 25NEO
3076 .82 rear .6 front cover
E85
1000cc injectors
044 intank
running 27psi :whistling:
Power FC
Blits Return flow cooler.
As paulr33 said. the exhaust will be a restriction before the cooler pipes will be..
Some yes - but the difference could be quite significant, meaning what you are reading on the pipe exterior essentially is useless information until you know whats going on inside.
Remember @ peak, 280rwkw there is a fair bit of air flowing (45-50lb/min IIRC). It's mostly going to be driven temp wise by how much work the cooler is doing, which is inturn also affected by how much pressure drop - or rather restricton - there is from turbo outlet to intake.
stock 25NEO
E85
1000cc injectors
044 intank
Power FC
Hahaha love your work! Im happy to run some big boost too, but damn 98 fuel and this turbo wont allow me anymore!
What exhaust do you run?
yeah sorry my bad im still running the standard cross over pipe aswell to go with the standard throttle body until i can afford a aftermarket throttle body. but your right im not running a return cooler only thing i can suggest is maybe run some ceramic tape on the piping where the they are close to each yes it doesnt look the best but if its performance your after it could keep the temps down i might be wrong but thats just my opinion
yeah 0.63 and as I told you before aswell im dropping boost aswell from 17 to 14 and still get that power so you will make it no worries, sure youll make more if you hold boost but yeah thats another problem to be solved.
