hey guys,
selling some parts i was going to put on my rb20 s13 however since selling it i have no use for these parts, plus maxed out my credit card buying some of these parts need to repay it
contact info: 0431445349 dan
if anybody wants a lot of these parts give me a call and we can work something out
inspections welcome
-spare rb20 fuel rail -$50
-spare rb20 cross over pipe bov section deleted -$50
-gt2835r turbo and dump pipe to suit -$900
-kkr430 turbo with dump pipe to suit -$400
-1L surge tank and 044 external fuel pump -$250
-denzo 800cc gtr injectors -$200
-arc bov -$100
-double din touch screen sony dvd player -$300
-d1 quick release hub -$50
-r32 gtst nismo 1.5way lsd -$800
-r32gtr/33gtst project mu hand brake pads -$150
-33 gtst brake calipers front and rear inc handbrake cables -$600
-brand new r33 gtst dba 4000 slotted and cross drilled, front undrilled, rears 5 stud. -$800
-S13 projector headlights -$300
-r32 gtr cooler -$300
post-54155-0-22586700-1302079127_thumb.jpgpost-54155-0-07222900-1302079141_thumb.jpgpost-54155-0-90246400-1302079149_thumb.jpgpost-54155-0-28231500-1302079172_thumb.jpgpost-54155-0-69103000-1302079186_thumb.jpgpost-54155-0-05623000-1302079207_thumb.jpgpost-54155-0-63666500-1302079224_thumb.jpgpost-54155-0-26334200-1302079243_thumb.jpgpost-54155-0-71375400-1302079255_thumb.jpgpost-54155-0-05124500-1302079269_thumb.jpgpost-54155-0-65118400-1302079285_thumb.jpgpost-54155-0-78196000-1302079304_thumb.jpg
https://www.sau.com.au/forums/topic/360035-r32-gtst-upgrade-parts/
