looking at upgrading my injecotrs and fuel pump b4 i get a tune and needing advice
in tank vs external which better? walbro vs bosch? looking for something that will fit in relatively easy without paying 3+ times the price to get a nismo one that will drop straight in.
what size injectors needed?
looking for 300awkw max but prob for better fuel ecomony and reliability will go closer to 250awkw.
300rwkw you might find will be OK with stock injectors. Some cars are, some aren't so as Jez said - just go with a fuel pump for now mate.
If you need them, get them. Otherwise you can tune to 280/290rwkw and save $700-$900 (purchase/fitting).
What turbos do you have? 300rwkw means non factory so you could probably make more if you did get injectors, you will need AFM's though.
not really keen on spending $600 on nismo pump which is more than 3 times price of bosch or walbro pump just coz its bit easier to install. from sounds of it unless i find a cheap set of injectors stick to what i got coz from what i can see like $600 sard 550cc injectors though the price to go to 1000cc injectors isnt much more.
so for fuel pump in tank vs external which better? walbro vs bosch? looking for something that will fit in relatively easy without paying 3+ times the price to get a nismo one that will drop straight in.
i got the N1 turbos, i tired searching several different topics nothing seems to come up but i get this alot guessing im just not using right words.
I have tuned a gtr 312kw stock injectors but a fuel reg.
250 kw is nothing for stock inj. Just get a fuel pump
What base pressure and afr bro?
But yea 250awkw is poossible with stock 444cc inj, even a little more......I'm doin roughly that now with them at 88% duty with 11.0 afrs,,,,and i'm sure your tuner wouldnt go that rich
Oooh ....an a walbro pump too....not in a gtr tho so i'm not sure about fitment
I tuned it at 11.5 afr. I never set the base pressure myself so i can answer that one sorry.
Inj hit 105%
There is a new fuel pump, just released not long ago. It flows nearly 350lph at 45psi. 290lph @60psi all at 13.5v.
Basically it flows just over 30% more then a failbro 255, denso etc.@ 13.5v. As another comparison
the walbro and denso need 16.5v to run close to this pump at its 13.5v flow on 0.7 SG.
Nismo quotes 276lph @ 3 Bar pressure, no SG or voltage quoted
The only downside I can see is that it will probably surge on under 1/4 tank on a bnr32- more of a design prob of the
tank then pump.
Its a 100% drop in, in tank pump and the best part is, cost is about $250
I will be getting mine in a few days and post findings
What brand? Anyone needing more than 255LPH is going to be aiming for serious power and won't care about a couple hundred $$ saved, and will probably NOT skimp on it given how much was spent on the engine.
But, see how it goes :)
tank then pump.
would like more info on this pump and also you findings
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
