Im going pedal box so i'll choose my own masters for the calipers i have.
Pretty sure its something to do with vacume. Theres only a few bolts holding them on so see if you can borrow one off a GTR to see if it does anything.
Luke, what does this thing do? You said it's a separator, so it separates vacuum? air? from what?
And I don't think it would feel any less spongy with this thing on.
Boz22n, what diameter BMC did you end up using? What bias adjuster? Ever had any troubles with adjustment range being insufficient, i.e. too much/not enough front/rear bias?
I think it is a 1"1/16 ? the bias is great the prob with the GTR master is the proportion is out for a GTST F/R weights etc.
Bm57 didnt change it one single bit :(
The thing on the left is the thing i didnt have which i think may fix it if i did keep them.
IT WORKS!!!!!!!!!!!
borrowed this off a mates 33gtr today and plugged into my stock BM40. with the lines it comes with as you still need the one way valve , pedal feel was fantastic, a huge improvement, even with stock master
now too get my own
It doesn't. But I think he meant proportioning valve that is built into master cyliner on GTRs, has wrong bias for weight distibution of a RWD skyline.
Patrol has no integrated bias adjuster in its BMC, so external adjuster is necessary.
I found this "vacuum can" in FAST. It's called "tank-assembly vacuum" in there and has a partnumber 47110-24U01. Must be inexpensive, so if it really improves pedal feel, it may be worth spending a couple of $ on.
How does the size of the master cylinder effect bias?
Only guessing here but I would say the diameter has nothing to do with it but if you pull one apart you will see there are two pistons inside and i would guess its the relative travel of those pistons and perhaps the size of the apertures that makes the difference. My car is not quite running yet but I don't expect any problems in my heavy Stagea. Relative size of brakes also makes a difference - whether you are just putting big brakes on the front and by how much you are beefing up the rears.
Ah ok so it's integrated rather than the GTST one which screws in?
It is integrated  in that the BMC body is cast with provision for the integrated prop valve. But the valve internals themselves are then screwed in. Attached are pics of disassembled BM44 prop valve.
BMCs with no integrated valve, like on Patrol and Pathfinder have no valve body cast with them, as seen on the third attached pic.
Actually, I would suppose that other than piston diameter and bias-controlling spring GTR BMC is identical to GTST and GTS BMC.
Since on tandem master cylinders like ours both pistons are attached to the same rod and has same travel for a given pedal input, I'd say it is only piston size that may be different
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
