  • Replies 386
below list now amended with new pricing! these prices are cheap :)
i also have the full set of relays and other odds & ends like the interior light, bonnet release cable etc etc...
1. os giken triple plate clutch (I paid $3000 for this & it’s only done less than 5000km, ALMOST NEW) - $1150
2. blitz icolor dual solenoid dsbc boost controller (I paid $1000 for this, NEW CONDITION) – $400
3. factory rb26 fuel rail - $20
4. 17" forged Work BRS Poison wheels with bridgestone tyres - price drop $550
5. factory side skirts (black) – price drop $90
6. momo gearknob - $30
7. factory triple gauge in centre console - $80
8. autometer air/fuel ratio gauge 'pro-comp ultra lite' series (silver face) – price drop $50
9. rear boot plastic trims which sit on the top of the rear tailgate - $20
10. cometic metal head gasket (has done 30min of work) – $50
11. 2 x earl's fuel filter with 5/16 barb push on fittings $30 each
12. front a pillars (3 small holes in dirvers side) – price drop $80
13. full set of nissan wipers (now resprayed) – price drop $20
14. front sway bar with linkages & brackets - $20
15. rockford fosgate 'punch series' 2 way speakers with additional tweeter & cross over (retail $500) - $180
16. alpine head unit with 2 sets of rca's – price drop $100
17. front windscreen – price drop $60
18. attesa 4wd pump – price drop $140
19. hicas pump – price drop $40
20. drivers side window/mirror control - $40
21. sun visors - $5
22. complete boot trim – price drop $50
23. instrument panel surround (does not have headlight switch) - $10
24. power steering line - $5
25. caster (radius) rods – price drop $20
26. radiator overflow bottle - $5
27. passenger & drivers side door sill garnish – price drop $20
28. front subframe - $10
29. bootlid rubber seal (no tears) - $5
30. power steering reservoir - $5
31. passenger side window switch - $15
32. 2 x rb26 timing belts (have done less than 5000km) - $20
33. 2 x rb26/30 timing belts (have done less than 2000km) - $20
34. factory rb26 harmonic balancer - $60
35. gearbox cross member - $20
36. front gtr seat covers like new (not faded at all) – $40
37. rear nismo seat cover (slight fading on top of cover) – $20
hey bud can u pm me some pics of these
complete boot trim
complete boot trim
pics sent!
hi guys,
i have a full set of DTM Rush wheels which are 18x9.5 with +25 offset, as shown in the pic of my black gtr.
sat well on my gtr & there were no clearance issues at all!
1 wheel is damaged from an accident as per below pic & i've spoken to "Magman" here in sydney which may have used here on the forum & he quotes under $100 to repair this.
with kumho tyres which have over 70% tread, i am looking for $900 (always negotiable)
Pics of the 17" work wheels to [email protected]
if you have any on the car would be great also? also what is offset?
cheers
pm sent!
pics can be seen in this link: http://www.skylinesaustralia.com/forums/topic/360230-r32-gtr-parts-for-sale-i-am-wrecking-go21la/page__view__findpost__p__5786990
offset is +29, tough stance :)
17 x 9.
list is getting smaller :)
1. dtm rush wheels 18x9.5 +25 offset with kumho tyres 70% tread (1 damaged wheel & repairable by "Magman" for under $100) – price drop $800
2. 17" forged Work BRS Poison wheels 17x9 + 29 offset with bridgestone tyres – price drop $500
3. factory triple gauge in centre console - $80
4. autometer air/fuel ratio gauge 'pro-comp ultra lite' series (silver face) – $50
5. rear boot plastic trims which sit on the top of the rear tailgate - $20
6. cometic metal head gasket (has done 30min of work) – $50
7. 2 x earl's fuel filter with 5/16 barb push on fittings $30 each
8. front a pillars (3 small holes in dirvers side) – $80
9. full set of nissan wipers (now resprayed) – $20
10. front sway bar with linkages & brackets - $20
11. rockford fosgate 'punch series' 2 way speakers with additional tweeter & cross over (retail $500) - $180
12. front windscreen – $60
13. attesa 4wd pump – $140
14. hicas pump – $40
15. complete boot trim – $50
16. instrument panel surround (does not have headlight switch) - $10
17. power steering line - $5
18. caster (radius) rods – price drop $20
19. radiator overflow bottle - $5
20. passenger & drivers side door sill garnish – $20
21. front subframe - $10
22. bootlid rubber seal (no tears) - $5
23. power steering reservoir - $5
24. passenger side window switch - $15
25. 2 x rb26 timing belts (have done less than 5000km) - $20
26. factory rb26 harmonic balancer - $60
27. gearbox cross member - $20
28. front gtr seat covers like new (not faded at all) – $40
29. rear nismo seat cover (slight fading on top of cover) – $20
I really didn't want to sell this but the fact is that I don't use it.
Unmarked nismo black urethane gear knob (like new) which I paid $160 - selling for $100
the pic does it no justice whatsoever!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
