  • Replies 386
Hey mate, got the coil pack harness? If so is it in good nick?
i do but unfortunately i cut it from where it meets the firewall - i only have the front half of the harness with all plugs
hows it goin? you still got the passenger side window switch and front subframe? if so how much to post to 2620? cheers. oh and do you still have the dash clock also?
passenger switch & dash clock are sold
subframe is still here :)...freight is $35 to your door (due to the size & weight of it)
another update, as below!
1. dtm rush wheels 18x9.5 +25 offset with kumho tyres 70% tread (1 damaged wheel & repairable by "Magman" for under $100) – price drop $650
2. 17" forged Work BRS Poison wheels 17x9 + 29 offset with bridgestone tyres – price drop $350
3. factory triple gauge in centre console – $70
4. 2 x earl's fuel filter with 5/16 barb push on fittings – price drop $15 each
5. front sway bar with linkages & brackets - $20
6. rockford fosgate 'punch series' 2 way speakers with additional tweeter & cross over (retail $500) – price drop $140
7. attesa 4wd pump – price drop $100
8. hicas pump – $30
9. power steering line - $5
10. radiator overflow bottle - $5
11. front subframe - $10
12. bootlid rubber seal (no tears) - $5
13. power steering reservoir (no cap) - $5
14. rb26 timing belt (has done less than 5000km) - $20
15. factory rb26 harmonic balancer – $50
16. gearbox cross member - $20
17. momo gear knob - $30
18. nismo black urethane gear knob – price drop $70
Marko, Just tried to ring you.. but you didn't answer.
Anyway, have you still got the BOV return pipe that runs behind the intercooler?
parts remaining as below:
1. 17" forged Work BRS Poison wheels 17x9 + 29 offset with bridgestone tyres – $350
2. factory triple gauge in centre console – $70
3. 2 x earl's fuel filter with 5/16 barb push on fittings – $15 each
4. front sway bar with linkages & brackets - $20
5. rockford fosgate 'punch series' 2 way speakers with additional tweeter & cross over (retail $500) – $140
6. attesa 4wd pump – $100
7. hicas pump – $30
8. power steering line - $5
9. radiator overflow bottle - $5
10. front subframe - $10
11. bootlid rubber seal (no tears) - $5
12. power steering reservoir (no cap) - $5
13. rb26 timing belt (has done less than 5000km) - $20
14. factory rb26 harmonic balancer – $50
15. gearbox cross member - $20
16. momo gear knob - $30
17. nismo black urethane gear knob – $70
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
