OK - Mum is too old for this shit now. Car has to go.
Conversion to Manual would make this thing a weapon, although the auto and high-stall combination makes for good drag stuff.
Only thing left to do is install a decent turbo/manifold/wastegate, which was next, but mum says no more!!! :flower:
This car isnt cheap. Genuine enquiries only.
Pictures in a couple of days.
1990 180SX Burgundy reg BP42WA - Lumpy’s Mum
Featured in Hot 4's some time ago with nowhere near these mods.
Engine
CA18DET
Bored & torque plate honed to 84mm with Arias Forged Pistons
Fully Balanced rotating assembley
Crank fully prepped – micropolished, deburred, balanced. Galleries grubbed
Tomei lightweight solid cam follower conversion
Tomei 260deg solid cams
Tomei Valve Springs
Tomei Cam sprockets
Tomei metal head gasket
Nissan Genuine Bearings
Nissan Genuine Water pump with custom made high volume impellor
Rebuilt Oil pump
Nissan Genuine other gaskets
Fully developed & ported head with heavy duty guides
Match ported manifolds
NICS removed
Polished everything
Candy powdercoated rocker covers
Custom lightweight/underdrive crank, alternator, water pump and power steering pullies
High flow thermo fan and shroud
Earles/Mocal oil cooler and remote filter
Custom aluminium radiator
GTR injectors
S14 T28 Turbo on ported original manifold
Autronic SMD management system with custom 4 channel coil control and auto-tune, stepping motor idle control, boost control, switchable antilag and automated rotational cooldown idle
Aftermarket coil packs
Turbosmart V port BOV in custom red anodise
60mm throttle body
600x300x75 intercooler with polished piping and silicone hose
Apex N1 exhaust, full polished stainless cat back
HKS 80mm cat convertor
Custom stainless front pipe
HKS split dump pipe
Full closed circuit draining catch can
Earles Braided line (with quality hose ends, not hose clamps!)
Rebuilt started motor
SR20 aluminium power steering pump
Bosch Motorsport fuel pump, in tank
Oddssey 800 battery
Serviced factory 4 speed auto
Dominator 4000rpm high stall convertor
Viscous LSD with 4.3 gearing
Massive trans cooler
Suspension
Whiteline sway bars
Whiteline poly bushes throughout
JIC radius rods
Apex Adjustable Shocks with Whiteline Springs
Cusco front Camber plates
Hicas removed
Carbon fibre front and rear strut braces
Brakes
R32 GTR 4 piston front calipers with 296x30 rotors
R32 GTR 2 piston rear calipers with 300x18 rotors
R32 GTR master cylinder (compatible with factory abs)
R32 GTR Internal drum handbrake
Braided rear brake lines
Nissan genuine pads
Factory ABS
Wheels/Tyres
DTM Fin 17x7 wheels
Uniroyal RTT-02 Tyres 215/45 front
Uniroyal RTT-02 Tyres 235/45 rear
Interior
S14 front seats
Factory head up display (still works!)
S15 leather shifter
Kenwood CD tuner
Rockford Fosgate front speakers, in stock location
Pioneer rear speakers, in stock location
Tint
Alarm with locking & battery back-up siren
Late S13 SR digital climate controller
Greddy Electronic Boost, Oil Temp, Water Temp & Exhaust Temp Gauges
Greddy single gauge A pillar pod
Hyperdrive 3 gauge on dash pod
Body
Carbon fibre bonnet (original bonnet included)
Genuine Wise Sports front bumper, modified and ducted
Genuine Nismo side skirts
Genuine Nissan rear mud flaps
Nissan Type-X rear wing (late model 180SX)
Clear front and side indicators
Factory Sunroof
Uprated headlight globes
Price $25,000. Will discuss offers and options.
https://www.sau.com.au/forums/topic/36025-fs-lumpys-mums-180sx/
Yeah, the car is here every Saturday. With the exception of a rego sticker, a small LUMPYROM sticker on each front gaurd, and a QEII hospital parking permit sticker on the window, there are no stickers.
This Sat it will be here for sure, as it's having photo's taken.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
