I am told that the new hiflowed turbo they do for around $1800 is equivelant to a GT3040
See the posts by B-man, he had a GCG rebuilt turbo that was meant to be a rough generic equiv to a 3040. It made great power up to 250rwks with a wack of boost...but then bolted on a HKS (ok so different to Garret but...) and got an extra 50-75rwks, so i dont think it is really an equivelant.
Good power, but 3040 power maybe falls a bit short... check B-mans posts
What sort of boost response would the 450 HP highflow have on an RB20DET?
I dont have a stage 1 but i have a stage two on RB20 with no tuning so you can atleast get an indication.
Mine starts to gradually build boost from about 3k, has 5psi by 4k, hits 7 by 4200 and then rockets to 11psi (i haven't upgraded fuel yet so am pegging it there at the moment) I have exhaust, cooler and pod.
It's a fair bet that the stage 1 will make good boost slightly earlier than this and the boost response will be less peaky.
Guest INASNT
Thats a very unresponsive turbo. I can get 1 bar by 4000rpm with a 600hp GT30 Garrett.
With regard to the GT3040 comment as i said is was told it was close to a GT3040 in one conversation and in a later conversation they said it was close to a GT3530???
BHDave how long ago was it that you got your stage 2?? Have you got a turbo from a RB25DET and bolted it to your RB20DET?? When i talked to GCG they said that the reason they didnt push the stage two is the reason yours is so laggy (i am guessing). They said as per SeriesIIGTST's post on page one that all those mods where necessary to get enough air flowing to booth spool the turbo and not restrict the flow of the air it is compressing otherwise it would be laggy.
I got mine second hand and it was about 4months old at the time, probably closer to 7months old now. Came off an sr20 actually. I'd killed my turbo and it came up for a good price so i got it as a bit of a stop gap.
Id reckon they may also run into surge problems on the rb20 due to the engine not being able to flow as much as the rb25 though i haven't got to that stage yet. Gimme a couple of months.
Guest INASNT
They will say anything to sell a product!! Have u seen the size of a 3040??? The stock turbo is half the size.
The high flow is so laggy coz u r still using the stock cast manifold which is a piece of shit!!
but the highflow std turbo is still a pretty small turbo, i wouldnt think that the stock exhaust manifold is too bad for such a turbo. My 2530 is roughly equivalent in size to a highflow stock turbo, and there is pretty much no lag.
I can understand on big phat turbos like 3040's that an aftermarket exh manifold would help, but im not so sure its worth the money on small GT25's or highflow standards???
I'm in agreement with Inasnt on the advantages of the A/M manifold.
Even on a small turbo the improved flow of the new manifold will give a reasonable gain.
Only problem with getting a decent manifold on an RB that I see is that the turbo will have to be moved from it's stock location in order to get a decent manifold in there so you will need custom oil & coolant lines, intake pipe and dump.
Not a huge problem, but enough of a pain in the arse that i'm leaving it for a while longer (it also has something to do with not having enough cash to do what i want when i want) :(
Which is why you port match the manifold to the head and the turbo and then have it power ported to remove the shit you cant get to. this drops the zorst temps down 40deg. having the exhaust housing done also help with efficiency.
watch the boost rise though!!!
sorry but i am a big believer in power porting
some ppl can't afford big turbos and A/M manifolds. been down that route.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
