11 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 64
Combine both those Autech bars.
The S2 is flat at the bottom, the S1 (1st pic) isn't.
I dont like how the S1 flares on the sides as it heads back to the wheel arches though.
Keep it even along the sides, have that cut out in the middle rear, THAT, on a series 2 Autech.
If its even, it'll make the whole car look better when slammed. A bumper that is uneven in edge (ie S1 Autech, Uras, Dianna, etc) looks shitty. More "boxed" shape like S2 Autech. Does that even make sense?
As Toffy said, widder to accomodate Aus plates.
Yeah it makes sense, I like the sound of it. It's simple, but combined with the larger rear plate opening will be enough to no be considered a copy.
No plastic, no care. Fuck fibreglass.
I'll just wait for a gen Autech to show up at a wrecker in japan. Or plastic weld the stock bumpers... doin my golf's ones atm... it's not that hard:
shan can weld plastic hey ? :whistling:
Easter break is gonna be balls out work on golf and ceffy. have you seen the cef lately? full sun fade on the roof. I need a fkn carport.
Everybody wants plastic.... anybody willing to put money behind their comments and help pay the $25K up front fee to make the mold?
I sure as shit don't have that kind of cash and if I did it probably wouldn't be spent on making something that potentially only 50 people over the next 3 years would buy.
We'd have more luck conducting an email spam campaign on TRA Kyoto to make a ceffy kit than getting a plastic one made here at a reasonable price.
lawl. I know a mob in China that will copy anything with no regard for copyright, and all their stuff is plastic. They make the kits for Wald.
Costs are:
USD$18,000 to set up a mould
USD$500 per kit (Front/sides/rear)
Minimum order 300 kits.
So if we get 168 buyers at $1000 a full kit we should break even. :ph34r:
Costs are:
That's not so bad if it was a more common car like an S13. $16.8K outlay for everything, sell the kits for $700 each and you make a profit.
Plastic welding isn't that hard , as long as you know the basics about the different types of plastic .
^^^ This.
It's actually easier than fibreglass when you get the hang of it. Hard part is matching up the different plastics.
Symmetrical Series 1 Autech.
Needs a lip IMO.
Series 2 FTW.
And on that note, how about bigger side openings....perhaps big enough to show off a small oil cooler, instead of intercooler piping? ;)
Edited by Nic_A31
Here's a quick chop - it's far from perfect - of a cross between the Autech S1 and TBO bars. Has a lip, larger & symmetrical air intakes and no indicator holes.
Thoughts? (aside from 'learn to photoshop')
That what's I was talking about when I asked about the indicator holes - not the side ones. I've never had any issues with not running indicators in the front bar even when the front bar fell off on the street a few times & I got pulled over for it, still no defect as the bar was in the car with me and I was 'on my way to the body shop' :)
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
