Hi all, I have decided to sell my 32 now, as i have found the perfect replacement car at an offer i couldn't refuse, so here are the details:
Basics:
'92 model
rb20det
5sp
Just over 104,000kms
Climate Control
Electric windows/mirrors
Black powder-coated stock rims
Timing belt changed at 98,000kms
Mods:
Pod filter
Boost gauge on A-Pillar
3" Exhaust (stock dump pipe, rest is 3")
Re-mapped chip (BadBiki chip installed by DrDrift)
Rear camber adjustable arms
Full Viper alarm system with keyless entry, bonnet/door/boot sensors, & a microwave sensor, Apexi pen turbo timer (fully automatic) all installed 3 months ago by Deny at Autobarn, Moorabin
Can sell an R33 GTR fmic with it aswell
Car has no stereo, but i can sell all the components needed for a little extra. (eg, clarion h/u, kenwood amp and sub in ported box, and some 6*9" and 6" Kenwood splits still in box, never used. Plus most of the wiring needed...)
And I just got the car re-registered, so it's got until late Feb '05.
Price-wise, i'm looking at $14,500, and that will include RWC.
If you would like any further info on this car OR THE SILVIA I HAVE FOR SALE, please feel free to PM me. I check it as often as possible. And as for pics, i have no digital camera, so if someone would like to take some shots and post them up for me, that would be fantastic...
Cheers.
Matt.
https://www.sau.com.au/forums/topic/36074-r32-rb20det-14500/
it's now down to $8k, has no rego, will supply a rwc tho, but if you visit www.nissansilvia.com it is under the Cars For Sale section... I haven't got any pics as i have no digi camera...
The Skyline and Silvia are still for sale
BUMP
https://www.sau.com.au/forums/topic/36074-r32-rb20det-14500/#findComment-734675
Still for sale, had a few interested parties, but no money, so yeah, i still have it... I'll take 14k cash, otherwise, it'll stay at 14.5 for a while longer. It's a pretty good price for an r32, you have to agree.
Cheers.
Matt.
https://www.sau.com.au/forums/topic/36074-r32-rb20det-14500/#findComment-749653
I'm afraid i haven't got any pics, as i have no digital camera, and no scanner, so it makes things a little tough...
But if you would like to see the car, please PM me with some details, and i'll get back to you as soon as i can. I'm South East of Melbourne...
Cheers.
Matt.
https://www.sau.com.au/forums/topic/36074-r32-rb20det-14500/#findComment-756806
Yeah Cattivo_69, the car is still for sale, but i don't have pics. (read the first few posts...)
I'm in Melbourne aswell, so if you would like to see the car, let me know via PM, and we'll arrange a time and place.
Cheers.
Matt.
https://www.sau.com.au/forums/topic/36074-r32-rb20det-14500/#findComment-759538
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
