when i put my foot flat down and go for it i get a weird noise from the back left like a tire rubbing noise , or simaler to it yet it isnt a tyre as im running my stock wheels and suspension still
its only under power that i hear it , if i accelerate like a nana or normal it doesnt happen
noise is louder when i have people in the car and only when under power , not cruising or nana accelerating ?
duno..
for a few of us..scott Craig and myself, when we put the car under heavy load theres a Vibration through the driveline.
mine sort of went away when i serviced the Transmission and transfer case, and a little more when I changed the oil in the diff's.
but its still there a little.
I noticed it really on became noticable when I lowered my car, so maybe its the same thing as you say when people sit in the car.
maybe havnt taken time to notice could this be my attesa pump by any chance
When you put your foot down, odds are pretty good that the car will transfer torque to the fronts so ATTESSA seems logical.
Have you changed the fluid in it yet?
no i might look into that as i had the car imported so am first new zealand owner , when it got serviced , complianced etc i thought they would taken car of all that but ye its only when car is working like actually working
got my 10000 k service coming up so will get that all looked at aswell with the weird sounds like cam belt noice from front when i turne car of so might be one of the belts ( not cam chain i know )
is the transfer case in back rear area or close to as ye its well cant explain but it only comes in after im through like 2 gear and power is down
Edited by Sidius
the transfer case is at the back of the gearbox.
sounds like an exhaust leak tho. youre probably not building up enough boost in first gear, but 2nd and above you are, and its pushing out a hole.
definatly not an exhaust leak i at least know that its rear right
my exhaust is rear left
ohh sorry i misunderstood as you said rear left in your first post. right where the exhaust is.
do you know which side is which? lol
my mistake and no its quite load and vibrates a little sounds like a tyre rub on speed yet it isnt ???
i think you mean attesa dude lol
there is a loop to run the pump on M35s
yeh? its also Ian, but you dont see me complaining LOL
so with servicing the attesa transfer case and or pump
any pointers , as in any mods that can be done while im there
nah. just use a 100% synthetic AT Fluid.
theres some how too's on the M35.info forum if IAIN helps you with the link
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
