when i put my foot flat down and go for it i get a weird noise from the back left like a tire rubbing noise , or simaler to it yet it isnt a tyre as im running my stock wheels and suspension still
its only under power that i hear it , if i accelerate like a nana or normal it doesnt happen
noise is louder when i have people in the car and only when under power , not cruising or nana accelerating ?
duno..
for a few of us..scott Craig and myself, when we put the car under heavy load theres a Vibration through the driveline.
mine sort of went away when i serviced the Transmission and transfer case, and a little more when I changed the oil in the diff's.
but its still there a little.
I noticed it really on became noticable when I lowered my car, so maybe its the same thing as you say when people sit in the car.
maybe havnt taken time to notice could this be my attesa pump by any chance
When you put your foot down, odds are pretty good that the car will transfer torque to the fronts so ATTESSA seems logical.
Have you changed the fluid in it yet?
no i might look into that as i had the car imported so am first new zealand owner , when it got serviced , complianced etc i thought they would taken car of all that but ye its only when car is working like actually working
got my 10000 k service coming up so will get that all looked at aswell with the weird sounds like cam belt noice from front when i turne car of so might be one of the belts ( not cam chain i know )
is the transfer case in back rear area or close to as ye its well cant explain but it only comes in after im through like 2 gear and power is down
Edited by Sidius
the transfer case is at the back of the gearbox.
sounds like an exhaust leak tho. youre probably not building up enough boost in first gear, but 2nd and above you are, and its pushing out a hole.
definatly not an exhaust leak i at least know that its rear right
my exhaust is rear left
ohh sorry i misunderstood as you said rear left in your first post. right where the exhaust is.
do you know which side is which? lol
my mistake and no its quite load and vibrates a little sounds like a tyre rub on speed yet it isnt ???
i think you mean attesa dude lol
there is a loop to run the pump on M35s
yeh? its also Ian, but you dont see me complaining LOL
so with servicing the attesa transfer case and or pump
any pointers , as in any mods that can be done while im there
nah. just use a 100% synthetic AT Fluid.
theres some how too's on the M35.info forum if IAIN helps you with the link
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
