Hi all, time has come to change up my set up as the entire engine package is getting revised including turbo system.
Up for grabs is:
1x GARRETT GT3582R 0.82ex ( Rear Housing HPC Coated Black)
1x Tial 44mm External Wastegate 1bar spring ( Body of Wastegate HPC Coated)
1x ETM (Extreme Turbo Manifolds) Steam Pipe Exhaust Manifold ( HPC Coated Black also)
1x Stainless 3inch Dump and Front Pipe with two O2 sensor ports
1x Complete Oil and Water line Kit to suit (all braid and speedflow)
1x High Polished 4in intake pipe with filter
1x New Nissan RB26 Exhaust Manifold Gasket in packaging still
Please note that the compressor housing is polished aswell . All HPC coating was done by Craved Coatings. Turbo kit has done approximately 15000km. This set up is extremely responsive and the manifold is a wonderful bit of gear.
This is a complete kit, the only thing that will need doing is the hot side pipe. The compressor housing also has an ally elbow welded on already so this is also handled. This kit will suit either R32 or R33 GTR.
Item Located in Townsville QLD 4818. I do apologise for not having any pics, i cannot get them off my iphone onto my shit PC. If genuinely interested please txt me and will be more than happy to forward pics and even video of turbo kit.
Asking $2900 + freight.
Best to email [email protected] or txt me on 0438840407
No time wasters please, this is a good price for a great kit :)
Cheers Marty
Edited by Weapon
https://www.sau.com.au/forums/topic/361002-rb26-high-mount-single-turbo-kit/
  • 6 months later...
  • 6 months later...
Hey guys sorry to bring through the bad news however this kit has been sold for quite some time.
The kit was exchanged for another kit with a cash difference. That kit has since made way for another kit now on my GTR lol
Thread needs to be closed.
Cheers Marty
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
