I'm pretty sure he ordered the hard race ones.
You are correct, in the middle of doing it now, replacing rear struts at the same time, will take before and after pics of the canber as well, although i will just be guessing how much to wind them out by, looks like probably 20mm longer than the standards would do it but i will do 10mm coz i will be getting it done properly thiss week when i get new rear tyres.
did you get the bush ones or pillow ball?
i think you wind them out to be same length as standard arms then when you go for alignment they adjust to what specs you want it
read this on whiteline site for one of their camber arms so i guess will be same :)
but pics would be great :)))
its ok to adjust them a bit longer than your standard. i did, and got them almost perfect. it was about 15mm i think. it looked like it needed about that much anyway.
it will all get sorted when you get it aligned properly.
here is a pic of the arms with the standard, the shorter one was how long i guessed it should be, i did wind it in a bit tho as it was too hard to get on the arm.
here is the arm installed, almost matches the cusco coil overs!
the camber before the install.
after install.
and what it does to the tyres.
Next step is to get them adjusted properly when the new tyres go on and then a tune for the 3540 i just put on :D
Do they looks as good in quality as they do in the picture? And do the bearings look decent in quality? Just curious as i was looking at these
The bearings seem ok, bit hard to see them as there covered by rubber, all else looks as good as they do in the pics.
A word of advice, when taking off the bolt off the body i suggest you get the car in the air and the wheel off hit it with some wd40 and go have lunch, come back every 5 minutes and hit it again, i hit the first one 5 minutes prior to trying to undo it, i almost pulled the car off the jack stands trying to undo it, after that every time i had to get up to do something i hit the other side with some wd40, once i went to do it was still hard but no where near as bad as the first side.
Got my hard race camber arms and jjr hicas lock bar, will take some pics on the weekend when installing.
i must say the hard race camber arms looks awesome compared to the jjr, not that the jjr look bad but the hard race look really well made, cant wait to install them.
got JJR rear camber arms- work perfect for a year or so now
JJR front toe arms with pillowball arent that great for everyday use. pillowballs are rooted already after around 7 months. would be good for drift or circuit car where they dont see speed humps and potholes.
  • 3 weeks later...
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
