Firstly this is a non-profit, non-business group buy i would like to organise.
There was a thread in the Vic section about this so please refer to it. I have decided to do this group deal nationally simply because we need to order a minimum of 35 badges. http://www.skylinesaustralia.com/forums/sh...ead.php?t=34963
I'll give you a brief overview of that thread:
Basically, I have spoken to a supplier who has made a sample of GTR badge except the 'R' has been replaced with an 'S'. The badges are made from 2mm aluminium. The "S" is etched out and paint filled and finally is glossed to offer a silver look or unglossed and has a more greyer look.
I have negotiated the price since that thread and he has come down to $36.50 each for the silver gts badge or $35 for the simple grey. The samples were $50 so to be honest everyone is paying for it within the price mentioned.
edited:
As soon as we get 25 badges confirmed ill collect $10 deposit on each badge and make the order. It will take 1 week from the day of the order for them to be manufactured.
Please advise which you guys would prefer and interest.
click here for pics
http://www.pbase.com/dskyline2c/inbox
cheers
https://www.sau.com.au/forums/topic/36119-gts-badge-group-buy/
  • Replies 110
To all,
I would be interested in two of the badges given that they come up to the standard of the sample i viewed the other nite.Can u pls pm me with details when they become available(final price and payment details etc...)
Regards,
SKYLINE (Kym).... :wavey:
To all,
      Regards,
no probz.....if u want to check them out just give me a buzz :)
and sori eriktufa we cant make the GT-T or else he'll have to redesign it
update: (8)
ME x 1
INASNT x1
jaqule x 2
WazR32GTSt x1
skyline x2
ABuSD x1
we've hit double figures woohoo
knore: it is mainly cuz of the influence of the GTR symbol...i mean where could we put the "t"?
update: (11)
ME x 1
INASNT x1
jaqule x 2
WazR32GTSt x1
skyline x2
ABuSD x1
Blade x1
krzysiu x1
eriktufa x1
14 more to go :rofl:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
