  • Replies 376
Posted Images
Also is there somewhere to block certain people from being on your team?
Keep on getting 1 same f**kwit in a beginner tank constantly messing around & blocking me on purpose...
:rant:
Edited by Mayuri Krab
All Telstra customers are getting lag at different times of day lately. It's not really a WoT issue, it's a Telstra issue. If you are connecting via Internode, iiNET etc there is no problem.
We should have a Lowe party, make a few platoons and que up together. :teehee:
Forever a Lowe
Those 'self-righteous, self-made moderators' are starting to piss me off!
I can't use my Lowe (or any premium tank) since every time I do one such ass kunt on the team will start shooting me mumbling his speech about how I'm messing up the balance of the game & he is doing the right thing by making the game fair... & when I kill him, I get reported for team killing...
Bunch of whining f**k wits!
I...never ever get this in my Lowe. Also let them shoot you, they will turn blue, then kill them.
I had an M6 shoot a team mate (not kill) then shoot my VK3601H, he turned blue, I ended him. Feels good man.
Don't TK, it's not a report system, it's automatic now and you can get banned.
I have just got some low tier premiums and I think alot funner than high tier battles as everyone rushes and doesn't camp
I got the t2 light and hotchkiss
the t2 light is the fastest tank in the game and in t1-t2 battles you drive circles around enemy tanks
and the Hotchkiss is like a mini maus as it has so much armour 95% of all tanks you vs can't penertrate your armour :P
I hated the T2, autocannons FTL. I have seen bugger all Hotchkiss in my M2 Light since the patch as they are reportedly more often in T3/4 matches than T1/2 these days. Probably easier to get into the T1/2 games with it in our time zone though.
I almost want to rebuy the MS-1, put the 45mm on it with gold rounds just to make Hotchkiss users cry.
Has any tried that other heavy premium tank in the same tier as the Lowe?
I think it is a USSR one?
Has more armor than the Lowe, but weaker gun.
I feel like buying one premium tank for every tier (that has one) & just has a massive armor advantage over everyone else & just act like arsehole :whistling:
ive never had my own team kill my lowe
but 50% of games theres always one 12 year old who doesnt get pocket money or his mummy doesnt want to use her credit card to buy the lowe who has a bit of a sook about wallet warrioring, even though if someone gave him a lowe he would use it and change his tune instantly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
