  • Replies 376
Posted Images
HawkEx (8:20:09 AM) You f**king premium twat, play without your premium shit for JUST 1 DAY n then you'll know how BIG moron you are.
HawkEx (8:20:40 AM) Still, no need to say to a premium retard who don't have brain to understand.. so f**ker play with our gold shells i nthat tank n show urself flamin mongrel
Tanks are srs bsns.
Especially for 47%ers
  • 1 month later...
Your kidding, mongrels
Only arty interests me out of the while time I played and I was in the closed beta for 6 months I've only played about 5% tank the rest arty
Then I have no interest in having you back :P
Arty is an irritant and ruiner of game queues.
Hahaha :'( ... Good arty you mean
No, all arty, it unbalances the match queues especially on SEA.
Also 8.3 is tonight, no clue why they do these updates on SEA at prime time.
Edited by DivHunter
Finally I get to drive the tanks endorsed by Chairman Mao... :yes:
Does anyone on SEA had a ping increase lately?
used to be 70-80ms, then went to 400+ms & finally have settled down to ~230-270ms these following days.
I want my old pings back!
Edited by Mayuri Krab
It's not just WoT, it's everything to Singapore etc because the SEA-ME-WE (hehe) cables are down so everything is re-reouted. Internode re-routes through Japan.
The Japanese tank tree is pretty funny.
FYI the top 100 games in each of the 17 Chinese tanks will recieve gold on Feb 10th counting games from when they came out until then. You just play, no screen shots or anything.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
