Billet Turbo- Hks Manifold And A Heap More Good Gear.
  • Replies 43
Posted Images
Turbo is still for sale... preffer to sell whole set up.
Is plain bearing type, however it spools better than the twin ceramic BB core they offer.
PM me if your keen
Still for sale:
Nismo r32 GTR dash- $250
Twin TD05 kit- $1000
Turbosmart FPR-800 fuel pressure regulator- $200
Turbosmart V port blow off valve- $75
VH45/Q45 V8 90mm throttle body- $250
HKS GT 2835- $350
RB26 Rods- $120
Generic intercooler- $100
Make offers, it's all gotta gooooo!!!!
Can bring some parts to the drift comp this weekend for peeps to look at.
Cheers
Justin
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
