More Mercury Motorsport Magic (Or Madness)
I want to give a very BIG thanks to the team at Mercury Motorsport for turning my GTR into something that is now simply amazing. The figures speak for themselves in the attached Dyno chart.
The chart shows pre tune 262 awkw and 465 awNm. Other than the Titanium Willall mid pipe and cat back system already installed, my car was dead stock. There was NO tune of any kind to support the Willall exhaust, So these figures are only slightly higher than a dead stock R35 GTR.
After Mercury installed their new 3.5" catted high flow dump pipes, a AAM Competition Air Intake system and the Cobb tune with their custom Dyno tune over the top, the results ramped up big time.
The acceleration has gone from brutal to totally savagely demonic!!!
As you can see in the chart my car now has 342.6 awkw and 625 awNm.
Not to mention the massive fattening out of both Kw's and Nm's throughout the entire rev range.
These are significant improvements, especially when you realise, that is an increase of 80.6 awkw and a wopping 159 awNm.
The guys at Mercury explained that, the percentage of drive train power losses does not stay constant when power increases, which makes sense.
This is interesting because even if I add NO extra Kw's or Nm's for further drive train losses and simply add the net at wheel power gains to the factory at crank specs of 357 Kw and 588 Nm, I now end up with 437 Kw and 747 Nm at the crank. WOW!
Due to the Titanium exhaust (largely) and air intake system (slightly), my car is approx 40Kg lighter than stock as well.
To say I am loving this car even more than I did before, is an understatement!
Anybody thinking of trading there 09 or 10 GTR in on a new 11, don't bother. For a quarter of the changeover price you can turn your existing GTR into a 2011 crusher. Unless of course they do the same?
I am so looking forward to my next encounter with the new Turbo Porsche. Just getting slightly ahead of them is now replaced with their total annihilation. Happy Days aheadrolleyes.gif
Edited by kymbo
  • Replies 52
not sure why your car only made 262kw with light mods and others made 291kw stock std
http://www.skylinesaustralia.com/forums/topic/224918-haltech-r35-gtr-at-syd-auto-salon/page__p__3961322__hl__auto%20salon
Great result Kymbo.
In respect of the J-Rad post people should not compare raw dyno results of one dyno to another dyno, unless they know how that dyno typically reads for a specific model.
I would have expected around 300awkw on a dd dyno as guide using standard mode.
However, as the dyno is a dyno tool just focus on the before and after results from the same dyno for the changes to a specific car run under the same conditions.
In this case the relatively change is huge, with no loss anywhere, and verified on the road.... and a happy customer.
Do you know how much more boost was added?
p.s I'm blown away by just how good the standard 11 is on the road, after 1600kms in 4 days.
Brian
Edited by bcl
As bcl posted, dyno testing is best used as a before and after tool to assist in measuring gains. Absolute numbers are difficult to analyze. The track and drag strip are a better way of comparing cars measured on different dynos.
Kimbo, was great to meet you the other day. Look forward to catching up at the track soon ;)
Thanks Brian & Mark
Yeh, I am stoked!
And you are both right. It is the before and after on 'that' specific dyno that is relevant instead of trying to correlate one dyno's figures to another. I could have taken my car to some other tuner on the same day and on their Dyno got a 50 awkw different reading?
Anyway, bottom line is, on that dyno, that day the Mercury guys got a huge jump in power over the stock power output. That NET figure is what matters, when considering how it fits in with improved output relative to the factory claims.
Look forward to seeing both you guys again in the near future.
Kymbo
Oh Yeh!
Forgot to mention, The Turbo's now boost to 17 PSI in the 342.6 awkw mode!
The stock boost was 12 PSI.
The new 'mild' setting now only boosts to 10 PSI, yet interestingly still produces the 260 awkw as it did with the exhaust only. This I believe is due to the extra hardware?
So a standard GT-R only makes 260awkw dead stock? Jeez when you put it like that you kinda have to think about how it is such a dominant force when 260kw is only a pfc and 14psi from an RB26.
Hi J - Rad, what is pfc?
Great result Kymbo.
Brian
Brian
Glad to hear you got your beast!
Enjoy!
I wasn't trying to bring up a dyno debate. Just saying that its power figures weren't all that high, yet it still manages to be so good at doing everything. Had nothing to do with figures or anything. I have no idea how much a GT-R should make at the wheels. Was a mere observation that a 300kw R35 is alot quicker than a 300kw R32.
No problems; even though heavier it does have 46% more cubic capacity and 18 years of development over an R32.
The 11 will pull around 124mph trap speed at the strip, so it is very good stock. Also, people often look at just peak power, when average power is far more relevant, and how the torque is delivered.
Brian
Oh Yeh!
On the 11 I'm seeing 15lb max boost on the boost gauge. I'm not sure if 12 pound is standard for the earlier model.
Cruising along at 2500rpm in 6th and onto the accelerator will see 15lb by 3000rpm. Factory spooling is pretty good, for what I believe is a non-billet compressor turbo.
As Mr Mizumo told us, the car (11) has more power than stated, and by seat of the pants I'd say he is correct. I'm going to take the car down wsid in a few weeks time, as I always see trap speed as a good indicative of power.
Brian
Brian
glad to see u've got your car back.
Would really love to see the monster myself.
I'll be there for the next meet up :D
enjoy the ride!!
Edit: the mods i have is pretty much the same as urs, beside the intake. mine is sitting at 328kw! that intake sure does make a big difference :D
Edited by fireboy
Torque and response - and gearbox, is what's predominately behind it.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
