Currently in Sydney
2G firm....
original aerotech buckets
VN group A (NSV build with build plate)
original CSA alloys...
identical interor to orginal and exterior with all badges...
(seats alone would be worth at least 4g........)
143000km
chris
0478058818
email: [email protected]
  • Replies 44
more pics to come when i find them....
wont let me upload i will have to alter the type and then upload.....
i know.... i had some on face book but the pics have vannished due to my Facebook account being hacked and/ or it being monitored by the feds / acers/ asio/ asssic / dsto intelligence surveilance and recon etc... will post them up when i can find them.....
the seats and rims are phat.... best buckets i have ever sat in from a factory spec car..... they are awesome....
has stiff suspension too...... damn stiff,..... handles like it is on rails however it could do with some expensive rubber....
no do not have any dyno sheets... it is prob not more than 120 kw at the wheels with the current set up... if need be i can get you a VP commodore motor with a twin turbo sr20 set up with dump pipes and cooler and piping aswell as braided lines that has been pro built for about 1600 more... that should be good for a safe 200kw at the wheels.... not bad for 3500 approx all up....
chris 0478058818
But dyno sheets help us tell how the car drives! It's an important part of selling a car, how else are we going to be able to tell how it behaves on the road?
Hi, can the stock R33 cat be included in this sale?
probably the only thing you would ever get related to gina -- some stocky exhaust part - (catconverter) and if you did happen to get sum, no doubt you would pay for it too............
pics of car please?
i have lost the cable that connects my phone to my computer so hence can not load photos of the car.... as soon as i find this cable i will upload.... for some reason the photos on face book that i have of the car are not supported on this site???
it is an unmodded stockish Group A where everything is identical to the real thing except for the transmission, motor and the steering whee (it was built by Northern SPecial Vehicles and has a build plate.....
if it had been modded and had been retuned due to having some form of engine management i would defenitely put in a dyno sheet... and if you were looking for a high hp car for either track. drift or drat (which this is not) i would agree with you that a dyno sheet is a must to determine how it behaves etc.....
However i know that you are being a smart arse product of a wank stain and put this comment in for a laugh due to the comments which started the macdoogle files hehehehehee... have a good day smart arse!!!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
