19 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey Guys,
Seeing as the last track day was a raging success I was thinking we should do it again.
I've added a poll to ask what track you think we should go to. I'm still in favour of Baskerville because it's closer to home and there is less things to run in to.
June 12th seems like a good day for it too. Both tracks are free from what I can see.
Cheers,
https://www.sau.com.au/forums/topic/362050-sau-tas-track-day-2/
  • Replies 171
Posted Images
Hey Guys,
Cheers,
this is a disolution the same as the drift guys. Symmons actualy has better run offs and the sand traps actualy stop cars. its been a while since a car has made as big a mess of itself as the Shaw s13 recently. Not having a go but just taking the bad omen off the track.
i want to do symmons one day this year...BUT..atm my car is not up for the high speed nature of it yet.. need to fix the gremlins before risking the long trip.
ive driven both tracks now and the speed is very similar. the back straight of barsky for me was 190 ish which is very similar to symmons depending on wind.
the long trip is another aspect. you guys could hire a room at cosy cabbins. cheap as chips.
ive only recently driven Barsky in lap mode and i can say its a far more exciting track for the driver. there is more to be gained/ learnt as an amature/ enthusist.
im very keen to bring my car back and try again.
its just a pitty that the track has a rubbish surface and that its subject to changing weather conditions every 5 mins.
+1 for barsky
Well that's a load off, I'm already peeing my pants about drifting there.
just had a look at cams calendar and june 11th is drift prac day at symmons. not sure if this will afect any of you guys but thought id mention it.
i will definatly be out if it is june 12th. that said dont arange it around me.
I might consider a go at baskerville if I get car running nice for this one. Seems baskerville got plenty of run off room for me to learn to use this thing called boost lol.
Need to get new coilpacks and possibly exhaust gasket and evaluate performance first though.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
