i know ur releasing the location later but can u just tell me if its down south or east coastish or wot? (im from devonport) so might be too much of a mission for me.
GTR + Highway for hours on end = Headache
+1 on this, I'm not committing to anything until I at least know the general area. As far as I know we could end up driving in a straight line for 3 hours and then turn around and come straight back :)
Is keeping it from the cops that big of a deal? They won't book anyone for doing the speed limit, and if everyone but me is going 150kph I think I'd rather find some nice bends by myself or just go with a mate..
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
