Hi Guys,
Please forgive me if i have done this wrong, never posted before.
I have reciently bought a 33 with a nismo lcd dash (not connected to anything) and was wondering if someone can help me out. At the back there is a RCA plug and 2 pins under it, im guessing there for power. Does anyone know which is positive & negitive?
any help would be greatly apreciated!
https://www.sau.com.au/forums/topic/362118-r33-nismo-lcd-screen-wiring-help/
yeah there is the ej1 and other systems,
I have a deck that plays dvd's and i was going to plug that in through the rca lead to test if the lcd screen works but i think the two pins below are for power and was just wondering if anyone knew which was neg and pos?
just to confirm for you, yes those pins are the power to the screen.
I have one of these in my car hooked up to the ej1 unit. But unfortunately off the top of my head I do not recall which of the pins is positive and negative, as mine was all ready to go with a power cable still fitted over them :P
Edited by Skysthelimit
  • 4 weeks later...
Hi i bought one of these nismo lcd cluster, but it only came with the navigation system..does the navigation work in australia and have english? also i have a motec ecu..if i cant find a epson ej1 system am i best off with the HKS CAMP or HKS CAMP2 ? please help if can
thanks
thanks
i had an EJ1 its broken the display chip is faulty and the display is scrambled.
Best bet is to get the HKS Camp 2 and the Nissan Consult harness it works really well and has allot more features compared to the EJ1.
You can also buy optional sensors for the HKS Camp 2 like boost, oil pressure, exhaust temp, oil temp etc
hey ok cool thanks for the help..ill look into the camp2
hey ive been reading throu some other post about the hks camp2..will it connect to a aftermarket ecu ?
There is a possability the HKS Camp 2 might work with an aftermarket ecu because HKS offer a CAMP 2 Universal Adaptor which has to be hard wired or soldered onto the ecu wires.
Apparently the Universal Adaptor can pick up the following...
SPEED, RPM, INJECTOR, and THROTTLE
Check out the HKS CAMP 2 FAQ's
http://www.hksusa.com/faq/?ID=3516
ok thanks again for the help will look into it more thanks
  • 3 years later...
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
