can i please get some pics of:
cusco half cage minus crossbar $300
sparco sprint fixed back $250
kts rear cradle bushes $30
very keen on them all.
cheers
Adrian
[email protected]
also keen on your nardi deep corn wheel lol and boss kit, for the right price... pics please?
Edited by The.Godfather
Hey mate was just wondering if you had any rear gtr Hubs that the driive shafts from the diff atttach to?
Hi all ,
decided to strip my car down.
all parts are still on the car , car is complete for now.
if people are interested in the bigger bits such as motor/box then ill have it stripped down quicker.
someone come chuck a deposit on the motor and box :)
cusco tension rod $80
d1 garage castor arms $80
project mu slotted rotors (front) $100
d1 garage rear camber arms $100
racing gear n1 circuit coilovers $1,000
nismo strut brace with cusco brake stopper $160
skyline rear strut brace $100
surge tank with lines and fittings $250
bosch 044 external pump $140
nardi deep corn copy $120
boss kit $45
hks evc5 ebc $300
gtr wing $150
rb25det motor minus turbo setup $1700 (needs new oil)
trust td05 with custom intake / greddy dump pipe / custom front pipe $1100
z32 afm $140
nistune rb20 ecu $400 (Tuned for engine setup with td05)
gearbox $900 (has slight whine)
18x8 /9.5 +45 $700
30mm bolt on spacers $100
27mm bolt on spacers $100
custom 2.5" blast pipes $250
Greddy boost gauge $60 (no light)
hicas lock bar $40
front mount intercooler with piping $250
signal straight through exhaust $600
r33 complete shell , with rego & plates $POA
cusco 2-way Mechanical Diff in housing $ 700
All parts sold as is
No warranty
Come inspect before buying
Postage at buyers expense
No COD
Will hold items if 20% deposit is paid on bigger items
If there is anything ive missed i will update the thread as it comes to my attention
contact: 0419 848 600
racing gear n1 circuit coilovers $900
boss kit $45
hks evc5 ebc $300
gtr wing $150
18x8 /9.5 +45 $700
hicas lock bar $40
rotors and lock bar?
how much is postage to 3041
still available, wouldnt be cheap due to the weight of the rotors.
hi, keen on gtr wing if its still available, pics??
inbox me your number and ill mms them across or email
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
