(this may not belong here so please move to appropriate forum if necessary)
I bought the car about 2 months ago now, and recently got my first rego renewal papers to see that the cars registered as an RB20 4 cylinder???
-How does this happen is it the previous owner or the D.O.T.'s doing?
-What do I do about this? Is it just as simple as going into a listening centre and telling them someone firetrucked up?
also I'm in WA if that affects the circumstance at all.
https://www.sau.com.au/forums/topic/362631-r32-gts-t-registered-as-a-4-cyl/
I might be wrong but I'd just leave it as long as you insure it for what is is and not go off the rego papers you should be fine
I wouldnt go through a blueslip or wa equivalent unless needed
My car is listed at the wrong weight on the rego papers and I've been told not to bother trying to correct it as it will end up costing me more than it's worth in savings if te weights bought down
Heaps of imports are regoed as sedans when they are clearly coupes and moat of the time people just leave it
Edited by stig mick
yeah, why?
Clearly the guy at the rta who put through the compliance papers never saw the car in real life
I had an S13 that said sedan, they don't even make an S13 sedan, and the back seats were only good for children under 5
So in other words, just leave it as is, would that affect the third party insurance included with the rego? Obviously I've got private insurance as well. But if I was to crash would I be screwed?
It wouldn't have any effect of 3rd party cause you were not the person who entered the details when you complied the car
Plus I'm sure the price for 3rd party injury would be the same whether it was 4 or 6 cylinders
Edited by stig mick
Alot of people belive it or not know nothing about cars they aren't interested in them so if they had an error on the registration papers how would they know so its not up to you to pick it up
I'm normally an honest person and would point this kinda stuff out, but if it's saving me money and because it's completely there fault I can't be held liable for any paperwork mistakes on their behalf it'll stay how it is.
I thought about telling them, but in the end thought "nah, its saving me about $15 per rego compared to my mum's V6 Camry, LOL", so the cheap arse Asian inside me isn't complaining... :yes:
The times I got pulled over & the cops ran checks through their data base on my car & they didn't mention anything about the 4 cyl issue neither (probably didn't know...).
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
