ITS DECA TIME
Saturday 4th June
And at this time we once again ask for your assistance.
For this event to run SMOOTH on TIME and SAFELY we need a small group of volunteers ( Officials )
to help out in 3 sections in the morning and 1 section in the afternoon.
And your assistance would be much appreciated.
All Officials on the day will be supplied with lunch and drinks.
A Officials briefing will be held before the drivers briefing so all Officials will need to be at
the Shepparton DECA Complex at 8.00am on the Saturday.
So if your thinking about coming up for a look and not competing this is a great way to get up close
to the action. And you will get a chance to do some passenger runs on the skidpan in the afternoon ( trust me ).
So if this sounds like you post up in here or send me a pm and i will put your name down.
Cheers WayneO. :thumbsup:
MORNING
Long Wang
STARTER.....Bec
TIMER .....Clive
FINISHER....Juliette
SPOTTER 1...Andrew
SPOTTER 2...Cass
Mini Wang
STARTER.....Anna
TIMER.......Tim
FINISHER....Campbell
Skidpan
STARTER..... Wayne
TIMER....... John
FINISHER.... Matt
AFTERNOON
Skidpan
30min ON and 30min OFF for this session.. :thanks:
STARTER.....Wayne
TIMER 1.....Clive
TIMER 2.....Anna
FINISHER 1..Tim
FINISHER 2..Campbell
As you can see we have had a fantastic response for the DECA officals.
But dont let this stop you putting up your hand to help out as these people will need a break through out the day.
Cheers. WayneO
Hey Waynos, swap the Campbells for Johnnys :)
Thank Tim.
Guys if your bringing your camera gear up and want to get up close to the action on the back track (long Wang )
We need a spotter out there to keep a eye on the action . So if you can lend us a hand let me know.
Cheers WayneO
It really hurts me to do this but I'm gonna have to bail from this DECA. I have some important expenses to take care of therefore I can't really afford to come this round. Haven't missed a DECA for years :(
Johnny won't be coming now either... Sorry guys :(
:O You suck dude...
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
