2011 Skylines Australia Vic Event Calendar (please note all dates are subject to change)
MAY
18 Wednesday – SAU Vic General Meeting – 8.00pm - Elgin Hotel - 75 Burwood Road Hawthorn (up stairs) - WaxIT presentation
20 Friday - SAU VIC Official Movie Night - Members ONLY (LINK)
JUNE
4 Sat - SAU Vic Import Monster DECA Motorkhana Day - Round 2 (link)
15 Wed – SAU Vic General Meeting – 8.00pm - Elgin Hotel - 75 Burwood Road Hawthorn (up stairs)
17 Fri - SAU VIC Official Cruise Night - Members Only (link)
JULY
1 Fri - SAU VIC Official Movie Night - Members Only (link)
9 Sat - SAU VIC Official Shooting Day - Members Only (link)
10 Sun - SAU Vic Track Club Championship - Round 4 - Sandown (link)
20 Wed – SAU Vic General Meeting – 8.00pm - Elgin Hotel - 75 Burwood Road Hawthorn (up stairs) (LINK)
AUGUST
5-6 Fri/Sat- World Time Attack Challenge - Eastern Creek, NSW - Click Here
12 Fri - SAU Vic Go Karts - Members ONLY (LINK)
17 Wed – SAU Vic General Meeting – 8.00pm - Elgin Hotel - 75 Burwood Road Hawthorn (up stairs) (link)
20 Sat - SAU Vic Track Club Championship - Round 5 - Phillip Island (LINK)
26 Fri August - Night Cruise - Members ONLY (link)
27 Sat - SAU Vic Import Monster DECA Motorkhana Day - Round 3 (link)
SEPTEMBER
10 Sat - SAU Vic Target Shooting - Members ONLY (link)
21 Wed – SAU Vic General Meeting – 8.00pm - Elgin Hotel - 75 Burwood Road Hawthorn (up stairs)
24 Sat - SAU Vic Track Club Championship - Round 6 - Sandown (link)
24-25 Sat-Sun - Track Battle - Round 1 - Calder Thunder Dome (link)
OCTOBER
7 Fri - Official Sau Movie Night - Real Steel - Members ONLY (link)
19 Wed – SAU Vic General Meeting – 8.00pm - Elgin Hotel - 75 Burwood Road Hawthorn (up stairs)
21 Fri - Official Sau Movie Night - Contagion - Members ONLY (link)
29 Sat- SAU Nationals Track Day (SAU VIC Championship Round 7) - Winton - (link)
30 Sun- SAU Nationals Show n Shine - Shepperton - (link)
30 Sun - WRX Club (non SAU VIC Championship) - Winton
NOVEMBER
16 Wed – SAU Vic General Meeting – 8.00pm - Elgin Hotel - 75 Burwood Road Hawthorn (up stairs) 12 Sat - SAU Vic Track Club Championship - Round 8 - Haunted Hills - (link)
19 Sat - SAU Vic Import Monster DECA Motorkhana Day - Round 4 - (link)
DECEMBER
Wed 21 - SAU Vic End of Year Meeting - (link)
4 Sun - SAU Vic Show n Shine Water Front City - (link)
Date Pending - SAU VIC Break Up Xmas Gathering
https://www.sau.com.au/forums/topic/363168-2011-sau-vic-events-calendar/
hi guys, so these meetings, are for members only? what does this mean exactly?
thanks
seb
Any events listed as "members only" can only be attended by Financial members of SAU-Vic
To become a member, check the website :)
http://www.sauvic.com.au/memberinfo
Whilst the club has a separate website, it exists "here" on the forums in terms of events, chat and so on.
You will also need:
- fire extinguisher securely attached to the car and within reach of the driver
- blue battery triangle 15cm x 15cm x 15cm
- two bonnet restraints, most cars have this standardhttp://www.skylinesaustralia.com/forums/topic/366732-sau-vic-motorsport-championship-round-4/
  • 1 month later...
  • 4 months later...
The 2012 calendar thread will be up shortly.
Currently no "firm" dates are known for Trackdays or other Motorsport/Cruises... So hence we've not created a 2012 thread.
Usually these dates come in Jan-Feb sometime :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
