If the compression is within 5% per cylinder then don't worry about the actual number (unless its under 100 or something extreme), it is almost certainly fine.
Lag could be poor boost control (line leaking), N1 turbos, leak somewhere. Can you get a graph of boost vs rpm? that often shows the issue.
I think you have one lazy turbo. One is overboosting to compensate, Best way to check it would be using two boost gauges one on each turbo and see whichone is boosting
They are both connected, they will read the same pressure surely?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
