Hey all, saw some some people sayin hey this is me so thought id do something about it
Im Taylor, live in the dirty south (bought a house in kambah 18months ago), own too many cars (99 RS4S stagea, 82 datsun 720 kingcab, 68 vw squareback, 71 vw fastback, 94 ED XR6 clone), used to own a modified 07 xtrail st-sX (full stainless exhuast, stainless ceramic headers, CAI with filter in the front bar, strut braces, custom 65mm KMAC lowered springs, angled manifold spacer, 18" murano alloys) but sold it for the stagea. im a qualified mechanic/rego inspector/wheel aligner, did my time on nissans and VWs, still working on VW's and shitbox holdens in belco. if anyone needs a hand with anything mechnical just ask me, even if your 80% though doing something yourself and get stuck im always willing to help (unless you live in gunners in which case you'll owe me a tank of petrol to drive to deep south sydney hahaha). also sold wheels and tyres for 2 years so if you have a question about tyres or wheels or offsets or rego then shoot me a PM.
So the ride is a 1999 Black Nissan Stagea RSfour S, for those who dont know RB25DET NEO powered 1700kg Manual wagon with R33GTR driveline, altessa and hicas etc. it has twin sunroofs, factory tinted rear safety glass, factory xenon HID headlights, R34GTT style interior, self closing rear hatch, climate control. i bought this thing locally bone stock, the only mod is a greddy full auto timer. so far have bought complete R34GTT calipers and slotted discs (factory brakes are kinda shitty 2 spot floating fronts with 296mm rotor where as R34GTT are 4spot fixed caliper with 310mm rotor) and HSD coilovers (according to the box 5/5 spring rates but worked out at 7.7/6.2 on a spring rate calculator), im yet to fit either of these due to our baby is on the way in the next week or 2 and knowing my luck il pull the brakes apart and il need to drive to the hospital haha. bought a headlight restoration kit on spesh from repco yesterday for $33 because the headlight lenses are cloudlyas . the end
oh yeh and...
https://www.sau.com.au/forums/topic/363444-better-introduce-myself/
cheers lads
nah i hadnt seen that autech model for sale. looks good though i dont like the interior and the cluster seems to be from an auto but its manual? not sure but maybe series1 260RS's are like that though
all the autechs were actually bought straight off the line from nissan as RB25 auto, taken to the autech workshop and converted to RB26 manuals there...
good to see another stag around! i've got a white RS4s, currently has a black front bar but FINALLY looking at painting it soon.
D.
pintaline - yeh ive seen you about 5 times but i was in various cars. saw you in braddon during summernats when i was driving dads red 57 plymouth and i yelled SSSSSTTTAAAAAAAGGGGGGEEEEEEEAAAAAAAA out the window when u went past hahah. is that black bar standard or dayz?
the amount of time ive stopped at the lights and people have walked past the car mouthing "whhhat thhhee faaarrkk" is hilarious. yeh cops dont even look twice at you its awesome.
black dayz bar aye :whistling:
at jax in phillip, was office bitch and rego inspector 80% of the time.
haha, i fought to get it, if you can find a white one, id be happy to swap :D
jax mitchell here, bit over 3 years there now, i do a bit of everything really
D.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
