Hi guys, I had a small accident where the car bottomed out and dented the middle pipe that joins the cat and the muffler. Its a genuine trust 90mm titanium exhaust and the pipe is just straight with one slight bend.
I was wondering whether this could either be repaired or if someone could refabricate an identical pipe. Its 90mm titanium pipe which goes from the cat to the muffler of my R34 GTR. I can post pics if required. Anybody know where I can get this done??? I'd like it refabricated in titanium if possible...
Nope, there's nothing listed on their site. I had a good search and rang around a few suppliers over here and hit a wall. I can import 3 inch Ti tube from the US, minimum order was 30m, 12k delivered. Getting flat sheet rolled was the other option, but have you seen the price Airport metals wants for a small sheet?
AM Performance here in SA have Ti tube in stock in various diameters.. limited stock atm and more coming in.
problem is it may not match your current wall thickness. AM can carry out the repair if you cant find anyone locally but you'd need to send the damagedsection to him.
I'm happy to send the damaged section to AM as the titanium is light as, whole exhaust is only 6kg so can't see this pipe being more than 2kg as most of the weight would be with the muffler. They seem quite expensive but you get what you pay for and I'm cheaping out on an R34 GTR...
Anyone got a contact # and or email for them???
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
