Hey guys i have a S1 R33 For wrecking it is currently complete and running So if your interested in the motor sms or call me about it NOW!!!
so you cna see it and ill even take you for a drive to show that the motor is good
Rb25det 120xxx Runs great if you dont have chance to see $1600 Runs fine Pretty firm
i also did a compression test and all cylinders came up god
Rb25det Auto box Same condition i took the car for a drive and it felt fine $280
Everything is in good nick on the car Was not in a crash or anything
i have shit load of parts but the car is all fatory except for the s2 side skirts and s2 boot
List of parts: ( off the top of my head )
Head lights S1 300
boot with s2 wing 50
Bonnet 140
Std cooler 50
Steering rack 50
Std turbo 250 Never ran over std boost Awsome nick
Front brakes 300 with hubs if needed
Rear brakes Calipers only 100
Diff 170
Front seats 150 No marks rips or anthing like that
Rear seats 70 it doesnt look like they have much fade at all
Std suspention 150 no leaks/ knocks
s1 ecu (auto) 50
S1 Loom (auto) 70
Std skyline Wheels 250 No scartches on rims comes with road worth tyres about 60 -70 % on them dont know what brand
after market wheels 400 light scatches
Rear bar 85 no marks price drop 70
Dash 90 no cracks or anthing like that
Rad 60 no leaks Price drop 40
s1 Afm 50
Tails lights 80 the pair SUPER CHEAP pirce drop 70
its also got a Small cat back exsaust ill get photos up for you guys $70 ( LEGAL )
Heaps of parts avalible Just Email pm or sms me
you can call but if its between 9-5 i prefer you just sms 0430106414 [email protected]
i also have a s14 so just ask for parts :)
https://www.sau.com.au/forums/topic/363576-r33-wrecking-lots-of-parts/
yup one has a pink sticker one has a green sticker
but as far as i know there copatible with eachother
i have friends with s2 motors running s1 afm's
and i know a guy thats got a s1 motor that has a s2 afm
ah okay :) i had a quick research and they seemed pretty similar :) might be interested in the afm for sale soon if no one's bought it by then :)
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
