Hey ppls.
I've been browsing the Nengun pages and I see these "Cooling Panels" (the one shown was for an S15) which look like they sit above the radiator to replace the standard plastic one...
Is there any advantage to these or are they pure rice?
Does anyone here have one for a skyline?
BASS OUT
https://www.sau.com.au/forums/topic/36444-cooling-panels/
www.nismo.com.au sells them. They are supposed to help direct airflow that comes in through the grill. I'm sure they had some sort of benefit, how much are they worth on Nengun? I personally wouldn't pay more than about $30 for one.
https://www.sau.com.au/forums/topic/36444-cooling-panels/#findComment-727184
As far as I can see they cut off airflow through the grill to the radiator. $150 ??? it is so easy to make yourself if you want one. cut a template from cardboard and transfer it to a piece of alum sheet from your local hardware about 0.8mm about $12. You can cut the stuff with heavy duty scissors. For Brissy people i've got template for R33 GTS25T
https://www.sau.com.au/forums/topic/36444-cooling-panels/#findComment-727872
Guest INASNT
even easier would be to take the alum to a place with a guilitione press, for $5 they will cut u the alum. Then u get that perfect cut surface
https://www.sau.com.au/forums/topic/36444-cooling-panels/#findComment-728531
Jay - I'd be pretty keen on getting a template if your willing to post to Canberra :(
Or even better, if you could post it up on SAU somewhere :rofl:
I've got a nice peice of alloy that I've been eyeing off for this project for a while now...
Cheers
J
https://www.sau.com.au/forums/topic/36444-cooling-panels/#findComment-728716
Guest darrinspencer
They guy's
I have made one this weekfor a 33GTST and will be doing a group buy next week
They are made from brushed stainless steel so they look very similar to the genuine ARC ones. No need to polish and keep polished like aluminium.
They are computer drawn, then computer plasma cut and professional folded
At he moment I will have 33GTST and soon have 33 GTR, s15.
If I can get hold of a r34 and r32 so I can copy them I will be making them aswell.
Price will be $70 plus post.
Darrin
https://www.sau.com.au/forums/topic/36444-cooling-panels/#findComment-738376
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
