post-54646-0-88291400-1305522625_thumb.jpgpost-54646-0-67218000-1305522639_thumb.jpgpost-54646-0-84674400-1305522650_thumb.jpgpost-54646-0-01000100-1305522547_thumb.jpgpost-54646-0-64281100-1305522560_thumb.jpgpost-54646-0-94003900-1305522573_thumb.jpgpost-54646-0-29520200-1305522594_thumb.jpgpost-54646-0-67677000-1305522609_thumb.jpg
Im selling a RB25/30 motor it is a complete rebuild, never used or fitted in a vehicle big money wasted no expense spared and due to other comitments can not continue my loss is your gain
Included with motor is;
- a custom made turbo manifold (high mounted)
- 38mm waste gate
- 72mm throtle body by plazmaman
- Vi pec computer in box
- GT 35 40r turbo
- Jatco 3 speed built by al's race glides
- 3000rpm stall converter & trans oil cooler
- RB25 plenum by plazmaman
All new parts and i have reciepts for everything, very regrettable sale as i have spent over $20000+ and alot of time.
$13,000 taking offers and not parting out at this stage
pm me for contact details
https://www.sau.com.au/forums/topic/364445-big-dollar-rb2530-package/
you need to give more info man, your not goin to get any genuine interest if u just telling the fellas on here that u though money at it..............
like i said champ posting on behalf of a mate ph: 0416 402 344 as he can give you a run down on the motor as its sitting at his mechanic still if u want to check it out and tell you specs
Edited by TUR-187
Have decided to part out
-block (chemicaly cleaned,crack tested,decked,bored,crank regrinded,forged conrods,forged pistons,cosmetic head gasket,18 head studs half inch thick,racing sump)$7500
- custom made turbo manifold (high mounted)$1000
- 38mm tial waste gate
- 72mm throtle body by plazmaman$750
- Vi pec computer in box$2250
- GT 35 40r turbo$1600
- Jatco 3 speed built by al's race glides 3000rpm stall converter & trans oil cooler$3000
- RB25 plenum by plazmaman$1000
$13,000 complete package
ph 0416 402 344
Closed.
If your friend wants to sell his engine on this forum, please ask him to join
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
